Old 02-21-2012, 07:22 AM   #1
Insrument panel and batt charging total loss
2008 Forest River Georgetown 373. 2007 Ford Class A chassis. Driving down the road total loss of all insturment cluster (except turn signal indication) and eventually Coach (not house) battery went dead. Seem to be interconnected. Talked with Ford 3 times. Repalced Alternator. Didn't fix. Finally wiggled wires looked for ground connection loose ... didn't find anything. Turned on key and all was back. Not sure it's fixed. Anyone else ever experiened this problem?
Johnee is offline   Reply With Quote
Old 02-21-2012, 08:17 AM   #2
tncruiser's Avatar
sound like maybe a bad ignition switch
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 02-21-2012, 09:49 AM   #3
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
I had a simular experience and the problem was the battery connection. It looked ok but when I wiggled it, it was loose and not making a good connection. The bolt going thru the connection was completely corroded thru. Replaced the bolt and cleaned the connection and the battery posts and put post treatment on both of them and haven't had a problem since.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 02-22-2012, 07:01 AM   #4
Thanks, the battery connection seemed ok, but I will take bolt out and check / clean / replace as necessary.
