Old 06-05-2015, 06:42 PM   #11
Send a message via MSN to Tiggerdad
Originally Posted by clarkchriston View Post
Looks great. Could the clamp be secured using c-clamps to hold the drain tube to the brass valve. I do not have the pex tools or clamps.
Use a Shark Bite fitting. Brass valves at Home Depot have Shark Bite fitting on one end. Shark Bite would slip over the end
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-06-2015, 04:50 PM   #12
hmmm, another project to add to my list...
akcampr is offline   Reply With Quote
Old 06-10-2015, 10:42 AM   #13
I did the same thing (shutoff valves on the low point drains) but had a different reason. I use my Georgetown 327DS in below freezing temperatures and didn't like the idea of water freezing in the exposed drain pipe. I cut both drain lines inside the plumbing compartment and installed the valves there. Before using the rig in cold weather conditions, I check the drains to make sure there's no water in them. At the end of a winter trip, there's no problems opening the drains to winterize the plumbing system.
I also added an electrical outlet and 250W of roofing heater strip to the plumbing compartment to prevent everything from freezing. I've had no freezing problems with outside temperatures dropping to around 15F at night. The remote thermometer I have in the plumbing compartment says that the temperature in there stays close to 40F when it's cold and the heating strip is working.
Phil
pmsherman is offline   Reply With Quote
Old 06-10-2015, 10:51 AM   #14
PVC valve
Originally Posted by bubbles View Post
Very nice install. Would something like this be easier?
Yes this is the way i did it too, cheaper than brass, might want to care a spare valve in case a wayward rock bust one
HotKreek is offline   Reply With Quote
drain, led, valve
