06-04-2015, 11:27 AM
Installed brass turn valves on my low point drains, much easier!
I got sick of using two wrenches to take off the low point drains to empty out my water on my 2015 Georgetown 351DS. So I installed these nice quarter turn valves. Makes the job MUCH easier for winterizing, or sanitizing the water system.
It is standard PEX 1/2" plumbing. I had to add extensions to each one because once I cut off the old valves, there wasn't much room up there.
Aaron G.
06-04-2015, 11:40 AM
Great idea!! I think I will do the same. I have a guestion... I see 4 valves...on my 2015 335 I have only found two drains..one for the fresh and one for water lines. Must be missing some, however, I had no issues after winterizing... blow out method.
Will and Patty
2015 Georgetown 335DSF
2012 GMC Acadia
2014 Harley Davidson Tri-Glide
06-04-2015, 11:41 AM
Yeah, this one has four drains, plus the fresh water overflow. Not sure exactly which goes with what. But this was a pretty easy job and will make my life a lot easier.
06-04-2015, 01:33 PM
During my PDI. that's the only drains they pointed out. I have the pex tools and clamps, so just need valves.
Will and Patty
2012 GMC Acadia
06-05-2015, 11:37 AM
Looks great. Could the clamp be secured using c-clamps to hold the drain tube to the brass valve. I do not have the pex tools or clamps.
2015 XLR 380 AMP
06-05-2015, 11:41 AM
I have done that to every camper I have had. Only I don't cut the line I just screw in the valve where the plug goes. That way I can take them with me when I trade in the unit to upgrade.
2016 Ram3500 4x4 SRW 6.7 68RFE 3:42
2014 Blue Ridge 3125RT
PullRite Super Glide
06-05-2015, 11:44 AM
Pex doesn't work with hose clamps. Sorry ...
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
06-05-2015, 11:51 AM
Very nice install. Would something like this be easier?
06-05-2015, 01:28 PM
I think it would be just as good but you need to add male thread adapters being the outlets are all female thread. I may do this myself for my water tank drain.
06-05-2015, 06:37 PM
Yes and they are in the same location as this is found in your hardware store of preference (male to male etc.). Very inexpensive.
06-05-2015, 06:42 PM
Use a Shark Bite fitting. Brass valves at Home Depot have Shark Bite fitting on one end. Shark Bite would slip over the end
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
06-06-2015, 04:50 PM
hmmm, another project to add to my list...
06-10-2015, 10:42 AM
I did the same thing (shutoff valves on the low point drains) but had a different reason. I use my Georgetown 327DS in below freezing temperatures and didn't like the idea of water freezing in the exposed drain pipe. I cut both drain lines inside the plumbing compartment and installed the valves there. Before using the rig in cold weather conditions, I check the drains to make sure there's no water in them. At the end of a winter trip, there's no problems opening the drains to winterize the plumbing system.
I also added an electrical outlet and 250W of roofing heater strip to the plumbing compartment to prevent everything from freezing. I've had no freezing problems with outside temperatures dropping to around 15F at night. The remote thermometer I have in the plumbing compartment says that the temperature in there stays close to 40F when it's cold and the heating strip is working.
Phil
06-10-2015, 10:51 AM
PVC valve
Yes this is the way i did it too, cheaper than brass, might want to care a spare valve in case a wayward rock bust one
