Old 02-21-2014, 10:52 AM   #11
Krazymace's Avatar
My rig has a thermostat in the bedroom, which is where the AC unit is located. Problem is, they are too close together. Bedroom quickly cools down and AC shuts off. Can only run the front AC on a more continuous basis. Wish FR would have put both thermostats in the same location to even out the workload of the two units. I have no idea how to relocate it.
Krazymace is offline   Reply With Quote
Old 02-21-2014, 11:19 AM   #12
Iwannacamp's Avatar
how bout this...
http://www.primetimerv.com/download/...structions.pdf
or search GOOGLE Dometic programmable
Iwannacamp is online now   Reply With Quote
Old 02-21-2014, 01:10 PM   #13
ramair's Avatar
Well I just found out that you can reset the the t-stat, which resets the computer board in the ac unit. Turn the tstat off once off push and hold the mode and + at the same time for approx 4/5 seconds and - -(dash dash) will appear. That will reset everything. Then you can turn it back on. Problem I was having was the furnace was not turning on but if you turned it off and then back on it would work fine. I think this solved my issue.
Sent from my SPH-L710 using Forest River Forums mobile app
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 02-21-2014, 01:59 PM   #14
That's good to know. BTW, I sent an email to Dometic asking if our units can be upgraded to the programmable Tstat. We'll see what they say.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 02-21-2014, 04:44 PM   #15
cjd10's Avatar
Originally Posted by Iwannacamp View Post
how bout this...
Camping World shows those on sale for $108. They should know if it would replace the stock ones
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 02-25-2014, 08:32 PM   #16
Phat Phrog Stunt Crew
awwall's Avatar
I thought I could do something with their 4 zone programmable, but it also is different. The use a special Cat5 interface and totally different control board.
I am anxious to see what they tell you....
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 02-26-2014, 01:08 PM   #17
here is my response from Dometic received today...
" Unfortunately at this time we don't have a t-stat that would replace the single zone and be programmable short of doing some rewiring in the wall. You are correct the multi zone system can be programmed and be set up for the way you would use it. Although it would require rewiring. Thank you and have a Great Day!!! "
So it can be done in a single zone system, but only if you are willing to rewire the whole thing. That sounds like a PIA to me, so I will just forget about it....for now....
David 01 is offline   Reply With Quote
Old 02-27-2014, 08:40 AM   #18
Iggy's Avatar
Lots of information in the thread.
ramir what actually does this do when you reset the AC units computer board?
Old 02-27-2014, 09:36 AM   #19
ramair's Avatar
Iggy
If your having issue with one off your units like I was resetting clears any memory and restores factory defaults. Hope this helps clear things up
2015 Ford Taurus
Our Baby Dachshund
Cammie
