Old 05-20-2015, 02:49 PM   #1
instrument panel
For some reason I lost the power to all my gauges checked the fuses and did not find any bad ones. This happen all at once has anyone out there got a answer. This is a 2002 325 georgetown
dreamcatcher1990 is offline   Reply With Quote
Old 05-21-2015, 10:18 AM   #2
WDK
WDK's Avatar
instrument panel
I assuming your lights work....while the slide switches are on that panel, do they work even though you may not have any panel lights, what is your battery voltage, check for a tripped circuit breaker.....
WDK
WDK is offline   Reply With Quote
Old 05-21-2015, 11:19 AM   #3
Dijoeboss's Avatar
If the tow-haul mode button is in the end of the gear selector, with key-on, press and release button and see if the tow/haul light ( or O.D. Light) comes off and on as the button is pushed, if it doesn't, it may be shorted. Which I would think you would find a blow fuse.
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 05-21-2015, 11:34 AM   #4
WDK
WDK's Avatar
WDK
Opps, wrong instrument panel.....your talking on the dash board.
WDK
