Old 12-27-2013, 03:52 PM   #11
raoulwv's Avatar
Just remember the formula Watts / voltage = amps. 2000/12=166.66 1000/12=83.33 and so on. Make sure your wiring can handle the current draw.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 12-27-2013, 03:55 PM   #12
Thanks for the advice.
vlevesque is offline   Reply With Quote
Old 12-27-2013, 05:40 PM   #13
That and stay as close to the batteries as possible.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 12-27-2013, 05:42 PM   #14
How about buying a cigarette lighter inverter like this http://www.amazon.com/s?ie=UTF8&page...ter%20inverter and start your onboard generator to power the microwave and coffee maker when needed. Just a suggestion.
2012WhiteSolera is offline   Reply With Quote
Old 12-27-2013, 09:55 PM   #15
Denver, CO
garbonz's Avatar
Best idea yet.
2017 Fuse 23T
Old 12-28-2013, 07:12 AM   #16
Your batteries are running in parallel, meaning that the output is still 12 volts but the capacity doubles. Make sure you connect the inverter to the correct poles so that you can benefit from both batteries. Here is a sample picture. Disregard the AH (amp hours).
Here is some good reading for installing an inverter:
RV Inverter Install: Four Different DIY Methods to Get off the Grid
Old 01-01-2014, 08:06 AM   #17
HookupAndGo's Avatar
We have one of the cigarette lighter inverters. I plug that in then run an extension cord back to where the kids need power for their electronics. Get a decent one that also has the usb plugs as well (then you can use that for phones/gps/etc).
Like the others have also stated, we then just run the Gen for the micro or coffee maker. Since we are in FL, we usually have the gen running anyway for the AC, only real exception is winter.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 01-02-2014, 09:35 AM   #18
I just bought the Bestek 300 watt inventor from Amazon. It has two outlets and two USB ports. Hopefully it does the trick. Thanks everyone for your suggestions.
Old 01-02-2014, 09:55 AM   #19
FYI
Power Inverter Wholesale,Car Power Inverter Supplier,Inverter For Laptop
grayfox is offline   Reply With Quote
Old 01-02-2014, 01:02 PM   #20
Great Horned Owl's Avatar
Originally Posted by vlevesque View Post
I'll have to check the size. They might be a 6 or 8 gauge wire. Maybe 1k would be better then. I will just have to shutdown breakers to things I don't need.
6 or 8 AWG is much too small unless your inverter will be within about 2 ft. from the batteries.
Plugging the shore cable directly to the inverter output will work fins so long as you always remember to turn off the converter. I wired mine that way, and all was well until the day I forgot to turn it off. The batteries ran down real quick.
I ended up connecting the coil of a normally closed relay to the inverter output. Then I used the contacts to interrupt the power to the converter. Now, turning on the inverter automatically turns the converter. To monitor the state of things, I wired a red neon pilot light across the relay coil, and a green on across the converter.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
inverter, power
