Old 12-27-2013, 10:22 AM   #1
Intellpower convert inverter hookup
Hi everyone,
I'm thinking about getting a 2k watt inverter for my RV. I was thinking that I might be able to hook it up to the battery connector point since one is free on the converter. When I'm driving down the road I would unplug the AC power from the converter and plug the shoreline power into the inventor. This way the people in the back can power their electronics and run the microwave and coffee maker. The batteries should remain charged because the alternator would be recharging them. Has anyone done something similar to this?
vlevesque is offline   Reply With Quote
Old 12-27-2013, 11:09 AM   #2
Not sure which rig you have. Ours came with an inverter from the factory to allow the residential refrigerator to be on while on the road. It has two 110 outputs and only one used for the fridge. When I get a chance I'm going to run wires to allow an ac plug inside the coach (probably in the kitchen area) to be used while on the road. I wouldn't run power hungry items through it though.
Our coach has three batteries. One for the engine, and two for the house side. The two for the house side are the ones that feed the inverter. I'd have to go out and see how it's wired, but I'm not sure the engine's alternator feeds the two house ones. I think those are maintained through a 110v charger that runs on shore or gen power.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 12-27-2013, 11:33 AM   #3
jergeod's Avatar
I do believe that anytime the engine is running all three batteries are being charged.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 12-27-2013, 02:58 PM   #4
raoulwv's Avatar
Originally Posted by vlevesque View Post
Hi everyone,
I'm not sure I understand your post. Are you proposing connecting the output of the converter to the input of the inverter? If so, it won't work. There is no output from the converter unless you're on shore power. Even if there was, a 2000 watt inverter draws 166.6 amps DC. Way more than most converters output. An inverter of that power should be installed directly to the house batteries using 4 gauge or larger cables.
On the other hand, if you are talking about plugging your shore power cable into the output of the inverter, that's also not a very good idea. Way too much current draw from your coach's AC electrical system for a 2k inverter.
I would wire a smaller inverter directly to the house batteries for the electronics and when it's time for the high power items (microwave, coffeemaker), start the generator.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 12-27-2013, 03:06 PM   #5
I just went out and verified with a multimeter that the batteries charge under all conditions (engine running, shore power, or generator). The battery control center takes care of switching between sources. That's good to know because that means that your residential refrigerator will not drain your batteries while on the road.
Old 12-27-2013, 03:19 PM   #6
There are two outputs for pos and neg. I'm assuming they are bridged together and not independent. I wouldn't be running the converter but just tapping into the lines coming from the battery. I don't know what gauge wire is coming from the batteries. I have a 2015 335 DS and the house batteries are right below the living are slide out making it difficult to run and cables directly into the coach. I'ld have to run them all the way back to where the converter is now.
Old 12-27-2013, 03:30 PM   #7
Denver, CO
garbonz's Avatar
Note that a 2 K inverter needs VERY large gauge wire, and if you have that wire gauge from your batteries to the dist box, there should be no problem. I'm guessing that you don't tho.
2017 Fuse 23T
Old 12-27-2013, 03:35 PM   #8
raoulwv's Avatar
I doubt they are large enough gauge. You'll risk burning up the wiring.
I would suggest more research before you try anything.
Rod & Carla B.
Old 12-27-2013, 03:35 PM   #9
I'll have to check the size. They might be a 6 or 8 gauge wire. Maybe 1k would be better then. I will just have to shutdown breakers to things I don't need.
Old 12-27-2013, 03:36 PM   #10
Yes, I don't want to be a rolling fireball.
inverter, power
