Old 04-13-2015, 08:20 AM   #1
Interior lights not working
I have a 2012 Georgetown 280 and have a perplexing problem that I'm sure someone has a simple answer to. Their are six ceiling lights (two in the bedroom and four in the front part of the coach). The bedroom ceiling lights work fine, but the remaining four do not. All the other lights inside the coach work just fine. I've checked the fusebox located back in the bedroom and the fuses marked "interior lights" appear to be fine. Are these four lights on a different circuit? Any help would be greatly appreciated.
mauidude is offline   Reply With Quote
Old 04-13-2015, 08:27 AM   #2
You might check the GFIC plugs in the unit. Sometimes one can trip and needs to be reset
trackmanbfa is offline   Reply With Quote
Old 04-13-2015, 08:32 AM   #3
Just tried the GFCI plugs. They are all working just fine. Thanks for the suggestion. Im assuming the four front lights are on a different circuit than the two bedroom lights. All the other lights work fine (e.g. under cabinet lights and lights above the couch).
Old 04-13-2015, 08:34 AM   #4
Not familiar with a 280, on my 378 there is separate fuses for
bedroom and living room lights.
mbtelguy is offline   Reply With Quote
Old 04-13-2015, 08:34 AM   #5
Most lights are 12V and are controlled by fuses not breakers or GCFI 110V.
Old 04-13-2015, 08:34 AM   #6
TURBS's Avatar
Lights are 12v correct?
Gfci ' s would have no effect on the interior lights if so.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-13-2015, 08:36 AM   #7
Is it possible that the front ceiling lights are controlled by the fuses located in the fusebox by the driver's seat as opposed to the fuses located back in the bedroom?
Old 04-13-2015, 08:51 AM   #8
bubbles's Avatar
Sounds as though you think all the lights are controlled by the same switch. Aren't the overheads controlled by a switch at the entrance by the step well? Have the lights ever been on?
Old 04-13-2015, 08:54 AM   #9
undr60's Avatar
I don't have a 280, I have a 300. The lights you are referring to in my coach are all turned on by a single switch located above the sink.
undr60 is offline   Reply With Quote
Old 04-13-2015, 08:55 AM   #10
Ha! Ha! I'm running for president of the dunce club this year. Thanks Bubbles. That did the trick. Found out that my DW had turned off the switch without telling me thinking it turned off the outside light. We got a good laugh out of this one. Thanks once again to all the wonderful FR forum members for helping out so quickly.
light
