Old 01-26-2011, 07:32 PM   #1
Interior room when slides are in on a 350TS and 357QS
I am considering the purchase of a Georgetown RV and looking at models 350TS and 357QS. I would like to know if anyone has any feedback on teh use of the RV while all slides are closed? Can the bathroom be accessed from the front? Can an adult get into the rear bedroom or a bunk bed if needed? I drive a lot while others need to rest and I cannot tell from the info I find on the web and I do not have a dealer close.
Also curious if you are happy with your machine?
Thank you in advance for your thoughts.
keithg is offline   Reply With Quote
Old 01-27-2011, 08:47 AM   #2
ronhanson's Avatar
The rear and bathroom can be accessed when the slides are closed. It's a little tight and if you are a big person very tight. I'm very happy with my 350ts.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 01-27-2011, 09:11 AM   #3
Thank you.
The photos help a lot. You have a great looking unit.
Old 01-27-2011, 11:34 AM   #4
kenandterry's Avatar
I agree with keithg.
Our 330TS also lets us have entire use of the unit with the slides in. Other brands of MH didn't always allow that, and we figured there might be times when we'd be a doing a sleep and run overniter, and not need/want to put out the slides. The only inconvenience was that you'd have to climb over the near side of the bed to get to the far side, instead of doing the walkaround when the slide is out.
But according to the floorplan layout, I don't see any indication of your TV on the bathroom wall behind the slide, but I do see part of a mirror.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-27-2011, 09:37 PM   #5
jsutherl's Avatar
I have a 2008 350TS. With the slides in everything is accessible except the bottom two rows of drawers (8 drawers I think) under the wardrobe. Also it's difficult to see the TV from the dinette and couch.
The bathroom door only opens about 2.5 feet wide so if you're a big person you might have to turn sideways to get through the door.
My daughter finds it easier to get in and out of the top bunk when the slide is in because she can brace herself against the bathroom wall.
When it's cold outside it seems a lot warmer inside with the slides in. Less surface area outside I guess. How I wish I had duel pane windows.
That's about it. I can't think of any difference other than those.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 01-28-2011, 08:56 AM   #6
ronhanson's Avatar
They didn't start putting the TV on the bathroom wall until 2010. My TV is up front above the center console which I think is now optional.
Ron Hanson
