Old 07-07-2016, 09:53 PM   #1
Intermittent Front Slide Operation
Good Evening,
I have a 2015 FR Georgetown 329 DS that I have had intermittent front slide operations with since I have owned it (1 Year)
Took it back to the dealer last year after it failed on the first outing and they replaced the solenoids but only because they couldn't get it to fail again while it was there (go figure).
Issue: Rear slide always works fine. The front slide works good most the time. But on occasion, I go to bring it in and it does nothing. Hit the button & nothing happens, no noises, no nothing. I reset the breakers, check the fuses and nothing is wrong. Happened again last weekend camping and now again tonight. Crazy thing is.... when I got it home last weekend it started working again (w/o any correct action). Prior to taking it to the dealer last year it did the same thing. Tonight, it extended just fine and then would not close. Currently hooked up to shore power at the house. But it happens on gen as well.
Has anyone experienced this or heard of anyone having this problem?
Appreciate any feedback or advise. In the meantime I have become a pro at manual operations.
FRGEORGE15 is offline   Reply With Quote
Old 07-07-2016, 09:58 PM   #2
Forbes's Avatar
I would look at switch or loss connection on wiring. Not a short that would blow fuse.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 07-07-2016, 10:11 PM   #3
Thanks. I am thinking switch maybe as well. I think I will look into replacing that to see if helps.
slide
