Old 09-15-2016, 08:37 AM   #1
Storey's Avatar
Inverter for Refrigerator
2015 Georgetown 350 XL looking to locate the inverter that powers the refrigerator. Fridge not working on 12 Volt, yes I have the inverter turned on however think it has a blown fuse or is defective. Cant find it though
Storey is offline   Reply With Quote
Old 09-15-2016, 09:28 AM   #2
RJJ
My floorplan is different than yours, but they put it in the pantry next to the fridge. I have to pull the bottom drawer completely out to see it. Not very convenient. It shouldn't be too far from the fridge. I think others have gained access through basement, they have to unscrew a round access hole. Hopefully someone with your model will come along soon and direct you straight to it.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 09-15-2016, 10:03 AM   #3
We have a different unit but try looking above the propane tank. There is a panel that has to be removed. I have had to do this many times so I just leave panel off.
2014 378 xl
2005 Jeep Wrangler TJ
jeffv003 is offline   Reply With Quote
Old 09-15-2016, 10:12 AM   #4
On my 335, which has an identical galley as yours, it is behind one of the round access ports in the basement directly below the reefer on the passenger side. I would bet that the GFI on the back of the inverter is popped and all you have to do is reset it just like any other GFI.
2015 335DS
ScottBrownstein is offline   Reply With Quote
fridge, inverter
