Check if any numbers are showing on the front display. There also should be a reset button on the plug receptacle, as well as the on/off button that needs to be switched on (check the on/off remote switch). If this doesn't fix the issue check the main breaker next to the control box under the entry steps. It should either be 80 or 100 amp breaker with a red lever.
If this doesn't help then reply. There are other, not so easy, fixes.
2013 Georgetown XL 378
2008 Honda CR-V
