Old 08-18-2016, 06:12 PM   #11
You will find a really, really big fuse or breaker in the power lines from the inverter to the batteries. Probably resettable breakers on the frame if you follow the cables to the batteries.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 08-19-2016, 04:29 PM   #12
vakeel's Avatar
On my inverter, which is in the same location, there is a GFCI button that pops out and you can push back in to re-set.
2013 Georgetown XL 377TS
vakeel is offline   Reply With Quote
Old 08-19-2016, 06:02 PM   #13
Thanks Vankeel but I'm not getting any power to my inverter at all. The GFCI may be needed after I figure out why I'm not getting power.
Juley
Traveling with my husband Rob and pup Murphy.
2015 Georgetown 360XL
JuleyT is offline   Reply With Quote
Old 08-19-2016, 08:00 PM   #14
chrisbailey13's Avatar
Look near your batteries. there should be a breaker that looks similar to this
that connects to the 12v wire that goes back to the inverter. It may have tripped.
You will probably have two of them under there.
2014 Georgetown XL 352QS
2013-2017 Days Camped-190
chrisbailey13 is offline   Reply With Quote
Old 08-20-2016, 08:03 AM   #15
Originally Posted by chrisbailey13 View Post
Look near your batteries. there should be a breaker that looks similar to this that connects to the 12v wire that goes back to the inverter. It may have tripped.
Thanks for posting this. I actually did find these when we had the original problem last week. One is for the leveling system which wasn't working at the time either. The other was not tripped but I reset them both anyway.
My photo from the original post. Breakers are in the white circle on the left.
This morning after reading your post I took the cover off the stairs and reset them again. Voilą! That did the trick. Thanks for prompting me to try it again!
Juley
Old 08-20-2016, 09:18 AM   #16
RJJ
Inverter Location
I knew one did the jacks, I've already had that problem. Did not know the other was for the inverter. Thanks for the info, I'll file it away for further use.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is online now   Reply With Quote
cat, inverter, location
