I'm seeing on my coach that the invisible film on the front is getting a greenish mold or dirt under the film. Has anyone found a way or know of any place that removes the film? It's depressing to wash the coach and still see this mess under the film. I can't imagine it's a simple process but any help would be appreciated.
If you wet the film with water and cover it with saran wrap for a few hours, keeping the saran wrap damp. It should peel off . It will be a slow process but the film is remarkably strong if you. Can catch an edge with fibgernails
I have read that its a long and tuff job. Some companies charge big buck to do this and there is no guarantee on the paint underneath. Some individuals say that you need a heat gun to make the film flexible and use plastic scrapers long and tedious. Wish you the best of luck and let us know how it goes. The issue you are having is mold growing under the film and when it was installed there could have been moisture trapped between the area.
