Old 11-08-2015, 07:04 PM   #1
kenandterry's Avatar
Is there another tow/haul fuse location?
I'm not showing any indication for the tow/haul light on my dash. There's no indicator during ignition startup and it doesn't matter how many times I push the button on the end of my gear selector.
I've tested the 20amp MAXI fuse in the power distribution box in the engine compartment, and it's good. I'm thinking this may be a little overkill for the fuse just to illuminate the tow/haul indicator on the dash.
Is there another fuse located anywhere else related to this feature?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 11-08-2015, 07:19 PM   #2
davel1971's Avatar
it's common for the wiring to the buttons to go bad. Very small gauge wire and the movement of the shift lever over time causes it to break
David & Lynn
Old 11-08-2015, 07:28 PM   #3
Iggy's Avatar
Yes it has small wires and the button sounds like it may be bad.
If I'm not mistaken you can pull the shift lever cap off that has the button in it and check it out with a ohm meter.
It also may be the brake pedal tow haul micro switch may be open or closed or just needs adjustment.
Iggy is online now   Reply With Quote
Old 11-09-2015, 03:36 PM   #4
Check your ford manual if you have one. My 337 has a chassis fuse box under the dash to the left of the steering wheel. I am having the same problem bu have not had the chance to check it out
Jim G is offline   Reply With Quote
Old 11-10-2015, 12:49 PM   #5
On my Dodge 1500 the first push disables over drive. To get to tow/haul I need to push the button twice. It does light up on the dash but it is very small and needed to check the owners manual to find out where it was.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 11-10-2015, 09:07 PM   #6
Another Ford F53 Georgetown owner could help
This is a Ford tow/haul issue I'm troubleshooting, so I'm asking anyone out there with their Ford F53 chassis to check their dash instrumentation at startup.
When you turn the ignition key to the "ON" position, just before turning the key to "START" the engine, do you see the tow/haul indicator anywhere on the dash light up, and if so where is it?
Ken and Terry
Old 11-11-2015, 07:24 AM   #7
bubbles's Avatar
I believe that fuse (no. 18) controls back up lamps, tow/haul switch and transmission control indicator light. I have read that the routing through the column of the tow/haul wires has been an issue with pinching and subsequent opening of one of the wires in the past. I think your chassis owners manual will show the location of the tow/haul indicator within the instrument cluster display.
Old 11-11-2015, 07:54 AM   #8
While we're on the subject of fuzes, I have a 2011 Georgetown 360 RB. As usual, when we go camping, something will screw up. When we got set up yesterday my CINCHAUS observed that the 12v receptacle on the center console fell apart when she unplugged the gps. We got it back together but it doesn't work, this getting kind of long so does anybody know where the heck the fuzes are?
tetsurvivor is offline   Reply With Quote
Old 11-11-2015, 09:17 AM   #9
RJJ
Kenandterry, hope this helps.
Name:	ImageUploadedByForest River Forums1447255020.463775.jpg
Here is my 2015 dash, not sure if it's the same on yours. This is with the key on, engine not running.
RJJ is offline   Reply With Quote
Old 11-11-2015, 09:22 AM   #10
RJJ
Tetsurvivor,
I hope this helps.
Mine has a fusible link, connected to the wires coming out of the back of the 12v receptacle. Make sure when you got it back together, both wires were attached to the rear of the receptacle. Click image for larger version
Name:	ImageUploadedByForest River Forums1447255324.515091.jpg
ID:	94097Click image for larger version
Name:	ImageUploadedByForest River Forums1447255353.045886.jpg
cat, fuse, location
