Old 08-03-2014, 10:01 AM   #11
Seventh Heaven's Avatar
Lol...well thank the good lord I figured it out!!! My darling daughter had shut off our main battery power switch and I hadn't realized it!!! We have a generator again!!! Thanks for all your help and sorry we had a bone headed moment!!
Seventh Heaven!!
2015 Georgetown 351 DS
Seventh Heaven is offline   Reply With Quote
Old 08-03-2014, 10:14 AM   #12
Plain Old Member
It happens. We've all had those moments. Some I was hoping nobody was watching or listening. Have a safe trip.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-03-2014, 10:21 AM   #13
So true...wish I hadn't put it on here for the world to see but ALWAYS appreciate the fast responses and great help!!
Seventh Heaven!!
Old 08-03-2014, 10:32 AM   #14
Ford Idaho's Avatar
Lock out / tag out?
Old 08-21-2014, 03:37 PM   #15
I was going to ask if your batt. sw. was on but I see you have allready been down that road. I did the same thing myself once.
johnnypal is offline   Reply With Quote
Old 08-21-2014, 04:57 PM   #16
It could be a problem with the fuel supply line. The line on my FR3 disconnected from the fuel tank. We figured it out and were able to pull fuel from an auxiliary tank when stopped. You can diagnose by opening the phillips screw on the carb. Prime the generator. If no fuel comes out of the open line, you've got a fuel supply issue. The other alternative is possibly a bad fuel pump. It's an easy fix. Test the line first and go from there.
hillcountry is offline   Reply With Quote
generator
