08-03-2014, 08:46 AM
Issue with our generator!
We are heading to Orlando Florida and out generator won't turn on/over...it makes a click click click sound like it is trying to do something but won't start up...any ideas? Details: Georgetown 310ds 2015 and Onan generator. Thanks for any help!!
Seventh Heaven!!
2015 Georgetown 351 DS
08-03-2014, 08:49 AM
Sorry meant 351ds...fingers slipped while driving!!
Seventh Heaven!!
08-03-2014, 08:54 AM
Plain Old Member
First guess is low voltage or solenoid. I'm guessing your house battery is at full capacity?
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
08-03-2014, 09:00 AM
Yes, it is at full capacity...sorry to admit I don't know what solenoid means...is there something I can do or do I need a service appt?
Seventh Heaven!!
08-03-2014, 09:01 AM
I had the same problem called the dealer but they could not get it in. The service tech said what happens alot is the battery voltage gets low and when the starter kicks out it gets hung up on a tooth of the flywheel, He said to put a wrench on the end of the crank on the engine and work it back and forth and is should break loose. It is a tight fit to get to it but i did that and it came free, never had it happen again but saved me from not have a gen for a long trip. I beleive it was a 17 or 19 MM wrench that was needed. Hope this helps.
08-03-2014, 09:18 AM
Sadly now we don't even get the click sound...ugh!! This is going to be a long/hot trip!!!
Seventh Heaven!!
08-03-2014, 09:23 AM
Plain Old Member
Have you tried holding the e-start switch to bridge the house and coach batteries, then cranking it? I know it's supposed to be to borrow power from the house battery to start the engine, but it works both ways.
08-03-2014, 09:26 AM
Plain Old Member
Worst case, can always locate a mobile tech enroute. Maybe at one of your overnight stops? Not sure if you're going near Pigeon Forge, but there are several around there that will come to you and are real fair.
08-03-2014, 09:37 AM
I know it wont start when your below 1/4 of a tank of gas, BUT will it even try?
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
08-03-2014, 09:42 AM
Full tank of gas so that's not the issue 👎😞
Seventh Heaven!!
08-03-2014, 10:01 AM
Lol...well thank the good lord I figured it out!!! My darling daughter had shut off our main battery power switch and I hadn't realized it!!! We have a generator again!!! Thanks for all your help and sorry we had a bone headed moment!!
Seventh Heaven!!
08-03-2014, 10:14 AM
Plain Old Member
It happens. We've all had those moments. Some I was hoping nobody was watching or listening. Have a safe trip.
08-03-2014, 10:21 AM
So true...wish I hadn't put it on here for the world to see but ALWAYS appreciate the fast responses and great help!!
Seventh Heaven!!
08-03-2014, 10:32 AM
Lock out / tag out?
08-21-2014, 03:37 PM
I was going to ask if your batt. sw. was on but I see you have allready been down that road. I did the same thing myself once.
08-21-2014, 04:57 PM
It could be a problem with the fuel supply line. The line on my FR3 disconnected from the fuel tank. We figured it out and were able to pull fuel from an auxiliary tank when stopped. You can diagnose by opening the phillips screw on the carb. Prime the generator. If no fuel comes out of the open line, you've got a fuel supply issue. The other alternative is possibly a bad fuel pump. It's an easy fix. Test the line first and go from there.
