Old 09-25-2016, 05:07 PM   #1
It comes in three's
It started by finding the rear stabilizer bracket snapped for the second time. Then I noticed the main slide had the rubber molding hanging outside. The rubber flap the went across the living room floor came off and was half in and half put where the rollers are. Then my wife saw the bathroom ceiling vent had the plastic lens completely shattered. I think to fix the rubber molding the entire slide needs to come out. I think everything possible on this RV has broken at one time or another. We are very sorry we bought this.
tjvpga is offline   Reply With Quote
Old 09-25-2016, 05:10 PM   #2
Iggy's Avatar
I had my rear sway bar bracket break on passengers side twice.
Ford replaced under warranty. Check with your local Ford dealer first about it.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 09-26-2016, 08:02 AM   #3
Fireman
Send a message via AIM to dutch
Bracket
I also had my rear passenger sway bar bracket broke loose twice from its bolts and bend the brackets so you could not installed it back on. Bought new one from Ford cost $ 8.00 and installed back on and tqour it down.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 09-26-2016, 09:00 AM   #4
kentdavido's Avatar
Crazy question. What do I have to do crawl underneath, and what would I expect to see if it had broken? Thanks
kentdavido is offline   Reply With Quote
Old 09-26-2016, 02:05 PM   #5
My sway bar bracket bolts broke twice. I thought it might have been added stress after I did the cheap handling fix, but have been told that this is not the case. The second time they broke I went to the local Ford dealer and he did not have the bolts, so he told me to go to the local John Deere dealer and get hardened bolts, which I did. Not long after that I had to take my RV to a Ford truck dealer for a recall and asked them to replace the bolts with original Ford bolts. The mechanic looked at it and suggested I leave the hardened bolts as they are better than the Ford bolts. Apparently this is a common problem, my unit is a 2012, I hope they have fixed the problem since then.
Jim G is offline   Reply With Quote
Old 09-26-2016, 04:27 PM   #6
2003 Georgetown 325
Hardened bolts is the answer. At least a #8 will do the job just fine.
reddiver is offline   Reply With Quote
Old 09-27-2016, 12:38 AM   #7
ramair's Avatar
I guess I have been lucky I have had no issues with my sway bar. But now I have said something it will happen.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
