Old 08-02-2013, 11:40 AM   #11
CLASS "A" Senior Member
cfsoistman's Avatar
EVANS TYPICAL ELECTRONIC ROTARY WIRING DIAGRAM.pdf
Evans%20Parts%20VS%20Ford%20Parts[1].pdf
Evans Tempcon, Inc
Here's all the info on the Dash AC Unit.
Sweating ducts is very common with high humidity. Pour a glass of soda with ice and what happens? The glass sweats due to the cold of the glass vs. the humidity in the air. The dash AC unit pulls air from inside on max, so unless you're cooling the entire coach with the rooftop ACs, the humidity is being pulled from the whole coach.
The whole unit takes 2-3/4 lbs R134a. There are charts showing ambient temperature and the pressures you should see on a set of refrigeration gauges. Without a proper set of gauges just adding refrigerant will cause a problem. Too much refrigerant is just as bad as not enough.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 08-02-2013, 02:45 PM   #12
It might be that the AC drain is not draining the water out fast enough on high humid days. I have seen some drain pipe installed facing forward thru the firewall so the wind/air pressure would not let the water drain. Also dirt plugging drain.
kittyskeeper is offline   Reply With Quote
Old 08-02-2013, 03:05 PM   #13
Steelhorzz
Steelhorzz's Avatar
Recap...
That was my thought, the Humid air in the coach is condensating when it touches the cold AC Ducts under the dash.
(Mine too was on max air, with the fan blower on high.)
When we reached Texas and points west, where the humidity was not as high... no water formed, or dripped on us....
However the question remains...
Anyone drive a car in those areas experience water dripping on them?
We drove our PT Cruiser in Savannah, Fredericksburg, Manassas, Gettysburg, and NO water dripped on us from it's AC ducts.
And the AC in that little car is COLD ! ! ! !
So I'm thinking the ducts in cars must be insulated, in some fashion to reduce contact with the surrounding humid air.
I forgot to mention EVERYTIME, I got out of the car my glasses fogged up!
So humid air... coming in contact with a cold surface... water forms...
I'll be crawling under the dash this weekend to take a looksee in the Cruiser.
Maybe RVs could benefit from additional insulation, (if that's the case).
Then maybe "colder" air would come out the vents.
I've traveled all over on business, and never had a rental car back east, or in the Midwest rain on me....
I'm not thinking there is a real problem with the AC ...
Just an opportunity to "upgrade" the RV in some fashion..
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
Steelhorzz is offline   Reply With Quote
Old 08-02-2013, 03:21 PM   #14
Come up to Minnesota where it's cooler!
Old 08-02-2013, 03:41 PM   #15
Iggy's Avatar
I'm on my way. I know I will need a umbrella also.
Here is todays Phoenix forecast.
Phoenix Weather Forecast and Conditions - weather.com
Old 08-02-2013, 04:24 PM   #16
Travler's Avatar
I have had cars have the drain line get cloged and cause the water to get into the cabin. If the AC has been running for some time it shuld have reduced the amount of humidity inthe cabin. If you are getting alot of outside air inside that keeps the humidity high then it could alow moisture to form on the duct work.
Check to see if you have water running out under the vehicle when it is stoped with the AC running. If it is a small amount or nothing then check the drain.
Travler is offline   Reply With Quote
Old 08-03-2013, 08:26 PM   #17
abjb's Avatar
Originally Posted by Iggy View Post
As far as I know it really is a great AC unit and cools very well.
Don't think it would be low on freon and keeps me cool in Arizona at 110 degrees.
Again this issue only happened once after running all day down the road in very high humid weather.
Iggy does you dash unit keep you cool without running the roof units?
When we bought our 2012 I asked if it would.
He answered yes.... in Main, Minnesota etc.
He then said you'll be running both roof units.
We didn't use the dash unit most of the way from Florida to Colorado in early July.
Originally Posted by Maddog378 View Post
On our 2011 378, we had the a/c compressor replaced underwarranty thru Ford. They prep the chassis, but the ductwork, fan, etc is Evans. Ours drips water occasionally, usually on AC MAX.
Ford replaced our compressor this spring.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 08-03-2013, 08:52 PM   #18
Oaklevel's Avatar
X2
My pickup did to my DW last week on the way home from the beach.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 08-03-2013, 09:53 PM   #19
Pete
gartonhl's Avatar
Good information. Hopefully we can keep this thread going as we have very little information about the dash AC.
I know it is NOT part of the FORD Chassis and it seems to be an EVANS unit.
Now how to find out how many oz of R143a it holds would help.
Anyone out there have any work done on their dash AC?
Any help or documentation would be helpful.
Has anyone used Artic Freeze Freon R134a out of a can?
CLARIFICATION:
We had a compressor issue May, 2012 and called Ford Roadside Assistance. Scott at 1-800-444-3311 stated that the compressor unit IS NOT a FORD compressor, BUT it is covered under the Ford 36/36 warranty. Our compressor was a "Sanden" unit that Ford put on the F53 chassis on our unit....2010 GT 378TS.
Called Evans-Tempcon also. They said they supply all A/C components from the compressor up into the motorhome, ie. ductworks and dash A/C control panel.
If your are having A/C compressor issues, my advice is to call Ford warranty service and verify your compressor unit.
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 08-03-2013, 10:08 PM   #20
Iggy's Avatar
ab&jb
Yes my dash AC keep us cool all the way from Arizona to Buffalo NY in late June and early July this year. On ethe way home is when the ducts leaked one time.
I have used my roof AC last year on the way to California going thru Desert Hot Springs and Palm Springs. Outside air temp was 109 degrees plus.
