12-24-2013, 08:25 PM
jacks
I have read ask the stuff here but none seen to apply. our jacks will not go down. glad it's not the opposite but anyone have any ideas? we are found all the right things ie engine is on, parking brake, etc. jo
Jo, Elliott, Cloey & Zoey (Havanese sisters)
Georgetown 2014 328TS; 2010 Toyota Corolla
12-24-2013, 08:33 PM
House batteries tires fully charged?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
12-24-2013, 09:40 PM
for sure. the batteries are totally charged. not sure what you mean about the tires. would we have a problem if they are new? Thanks
12-24-2013, 10:07 PM
If you have shore power, try shutting off the engine, plug in to shore power and then try.
That's how I put mine down. They take a lot of juice...
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
12-24-2013, 11:27 PM
yup tried that. guess this is what people mean when they say to buy used do the kinks will be out
12-25-2013, 12:54 AM
Reset the 12 volt DC breaker where your house batteries are and hydraulic system for levelers.
It will look like this. Push the red button and it is tripped.
Push the bar in and it is reset and you have 12 volts to hydraulic pump.
You can see mine located in upper left of picture.
12-25-2013, 08:17 AM
As Iggy said, you may have your latch fuses tripped. We have two in our coach. Once you push them in, you will have to reset the system and then redo the auto level procedure. Let me locate the procedures for you. I'll repost.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
12-25-2013, 08:24 AM
Once you locate and reset the fuse/s you have to reset the system. See below:
To reset, you just hold all four buttons simultaneously (front/back/left/side). To calibrate it, you have to manually level the coach and then tell the leveler system that it is leveled by turning the panel off, then on, pressing the front button 5 times followed by the rear button five times, then the retract button 3 times and you are set.
12-25-2013, 10:39 AM
Thank you all
Once I get my husband up from the floor after passing out at the thought of doing all this, he will give what you have all said a try.
12-25-2013, 04:15 PM
i do not remember. Must be spell check. Your tires have nothing to do with the jacks. Where is my beer?
12-27-2013, 09:43 AM
Thanks, we are working on this now!
12-27-2013, 11:04 AM
I like that statement, I can't think without a beer in my hand, now if my sweet, sweet wife would only realize that.....
Coachmen M/H
Concord
2018 / 300 DSC
12-27-2013, 11:06 AM
Perhaps she has...
Just sayin.
12-27-2013, 11:16 AM
I would hit the "All Retract" function, twice, letting it do whatever it does, then try putting them down. My unit seems to need that a lot lately, guessing there is a switch somewhere under there that needs set. Agreed on the beer, just wish my DW understood that!
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
12-27-2013, 12:15 PM
Why don't you try doing a hard reset to the system to see if that solves your issue.
12-27-2013, 12:52 PM
On mine, the jacks will not work unless the engine is running and the emergency brake is applied. Just checking to make sure you tried the easiest solution first...I forget the emergency brake every once in awhile.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
12-27-2013, 12:54 PM
jacks
ummmm what's a hard reset?
12-27-2013, 04:01 PM
That's when you take the hole system apart and rebuild it.
Just kidding. That's what I call removing power from the system, reset, and calibration. You can remove power by either disconnecting the battery or unlatching the circuit breakers (press the red button and then push the little lever back in). Then do this:
12-27-2013, 08:56 PM
hummm,you could just go to harbor freight get 4 floor jacks and a cheeeep level,,opps think i'll get nuther beer! just re-caliberate I have had to do that a few times,don't know why??
12-28-2013, 08:18 AM
I get more and more calibrated with every beer.
