Old 10-03-2009, 11:40 PM   #1
Unhappy Jacks do not work
I have a 2007 georgetown XL. I was going to relevel it one day, when I retracted the jacks I couldn't get them to go back down and then I found out that my slides didn't work either. All my lights were binking on the control panel for the jacks. I have checked all the fuses in the battery control box and the 90 amp breaker. Does anyone have any ideas?
virginiaboy is offline   Reply With Quote
Old 10-04-2009, 08:54 AM   #2
Jacks
I had the same problem. Under the steps (where your batteries are) look for a small rectangular box on the frame. This is a circuit breaker. You should see a small lever on the bottom of this box. Push it back in and this should reset the jacks. If the slide or jacks still don't work; you will have to take of the cover of the fuse panel located behind the batteries on the right hand side. Sometimes a fuse blows when the circuit breaker trips. Why this happens is anybody's guess; but one cause is : Trying to level without the engine running; it seems to draw too many amps; thus tripping the breaker. Good Luck.
Crossfire is offline   Reply With Quote
Old 10-05-2009, 07:45 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Crossfire's post is definitely the answer to your question. Here's a link to Lipperts Touch Pad operations and troubleshooting should you need it. It's pretty informative when it comes to the operations without reading 50 pages of information.
http://www.lci1.com/LIP/0021.pdf
I keep a copy in the motorhome just in case I need it.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
