Old 12-31-2013, 01:23 PM   #1
Jacks down slides coming in too far
Just getting ready for trip and had slide maintenance done recently including rail adjustments!
Went to 2008 Georgetown 374 this morning and front jacks are down....put slides out for checking inventory and when putting slides in kitchen and living room tried to come in too far vending slide framing outside.....left as is and proceeded to retract front jacks....ok, the turned off all power sources and checked outside...front jacks came down by themselves..no power on at all!
Heading to dealer later in the week hopefully without jacks coming down!
Has anyone experienced these issues....thanking you in advance,
George
ynott96 is offline   Reply With Quote
Old 12-31-2013, 09:21 PM   #2
Always Learning
No clue, just bumping the thread and hope someone can offer ideas...
Old 01-01-2014, 08:34 AM   #3
You are having some major issues with your hydraulics. I would somehow secure the jacks with wire or something and take it to a shop. Hopefully you have an extended warranty. Good luck.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 01-01-2014, 10:07 AM   #4
abjb's Avatar
Check post #’s 4 and 6 on this thread.
http://www.forestriverforums.com/forums/f16/bedroom-sliding-51955.html
Here’s another.
http://www.forestriverforums.com/forums/f16/front-leveler-slowly-sags-50412.html
Hope this helps and let us know how it's going.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 01-01-2014, 11:26 AM   #5
Had unit in previously for hydraulic problems..new pump etc.....wondering what went wrong...in to service center tomorrow morning..after cancelling trip to other coast for two week fun!
Old 01-13-2014, 08:32 PM   #6
Service center solved hydraulic problems by tweeking hydraulic valves! All is working well now~George
Old 01-13-2014, 09:41 PM   #7
What does that mean? Tweaking.....
The valves are open or they are closed electrically. No tweaking needed.
Old 01-13-2014, 09:53 PM   #8
Rupkin2's Avatar
My thought, the unit was in earlier for hydraulic issues.
Odds are they forgot/missed something.
"trust no-one" (X-files)
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 02-03-2014, 07:29 PM   #9
Update...left for Fort Pierce FL Feb 1, upon arrival putting jacks down..out of the corner of my left eye..............kitchen slide coming out!!!!!!!!!!!!!!!!!!!!!!
Continued leveling....of course front wheels off ground as usual with auto level...did manual best without taking wheels off ground...level site/concrete! Slides all put out..will be retracting and heading out Saturday....will update...but definitely dropping at service center upon return...again....George
Old 02-03-2014, 09:06 PM   #10
bubbles's Avatar
Front wheels becoming airborne is not a big deal. The only restrictive procedure is that all wheels should not be allowed to come off ground when levelling coach. My front wheels occassionally come off the ground when auto levelling and I'm sure this happens to a number of GT owners. The jacks can handle the weight with no problems and the coach is quite stable. It has never caused me an issue. Typically I manually level my GT because I'm used to doing it in my previous coach. Now, your slides should definately not be coming out until you select them to. Good luck.
Old 02-04-2014, 07:26 PM   #11
ramair's Avatar
definitely should not be doing that. unless they have the hydraulics messed up...
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
jacks, slide, slide out
