Old 05-15-2016, 09:01 AM   #1
Jacks down wont retract
Sigh, jacks went up but light still saying down. Put jacks down again and now they wont go up. Lippert maes awesome components. Stuck waiting to see if coachnet can help me.
fullenw is offline   Reply With Quote
Old 05-15-2016, 09:05 AM   #2
CaptnJohn's Avatar
Which system do you have?
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 05-15-2016, 09:34 AM   #3
VinceU's Avatar
One scenario I had with a Lippert system I had was a electronic failure at the pump/motor skid. Mine was located under the steps with pink fluid filled tank. Between the tank and the pump motor are lots of wire connectors. Locate the black and white wires connected into the pump manifold on the side of the assembly, not the top. May have to pull back some wire armor to find it.
This wiring is 16 or 14 gauge and controls pump oil fwd or reverse flow. If you can remove connector and all hydraulics will retract with normal button. If you reconnect. All items will extend. I had to do it this way for months, till FR located cable.
Old 05-15-2016, 11:19 AM   #4
kenandterry's Avatar
fullenw
I can't post a picture but look to see if the 100amp breaker has tripped. It's a small square plastic encased unit about 1"X 1" in size usually located on the vertical wall behind the entry steps.
Sometimes if you over do things with your hydraulics this breaker will trip.......you may even see a small plastic tab (sometimes red in colour) sticking out from the side. Just push it back in to reset.
Report back so we can see if things are working with our suggestions.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 05-15-2016, 11:21 AM   #5
abjb's Avatar
Check these threads for possible help.
LCI Motorized leveling
Hydraulic fluid loss
Post #5 and 11
Leveling Jacks Won't go down
LOTS of info on the forum you might want to do an advanced search for Leveling, Jacks, Hydraulic etc.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 05-15-2016, 12:14 PM   #6
Iggy's Avatar
Check your fluid level and the 100 amp DC breaker that supplies power to the pump motor.
Here is a picture of mine. If the small arm is out it is tripped. Push it back in.
Check your batteries cause low battery voltage makes this trip.
Iggy is online now   Reply With Quote
Old 05-15-2016, 12:35 PM   #7
Yah it's not the breaker. Tried the wire trick and nothing still. Motor will lower Jacks more but not raise it just whines.
Old 05-15-2016, 08:28 PM   #8
Check the ground connection for the jack. One would not retract as I took delivery. They finally found a loose ground wire. Glad it happened before I got it home.
AbdRahim is offline   Reply With Quote
Old 05-15-2016, 08:34 PM   #9
bubbles's Avatar
Have you tried resetting the system? You can release the parking brake and see if the jacks will emergency retract.
Old 05-15-2016, 09:11 PM   #10
Iggy's Avatar
What level is the hydraulic tank ?
If the motor will lower Jacks more but not raise it just whines it sounds like its turning.
If your level is too low it may not have sufficient fluid to do the job.
jacks
