Old 09-07-2014, 01:59 PM   #1
Jacks on my 2006 Georgetown wont extend ???
What can be the problems
Dynomike is offline   Reply With Quote
Old 09-07-2014, 02:06 PM   #2
Retired Ford Tech
Does the jack panel turn on ? If not check your slides, to see if they operate. If they're dead too, check the circuit breaker behind the step well. You have to remove the steps to access.
rvpezzano is offline   Reply With Quote
Old 09-07-2014, 03:34 PM   #3
The slides works ok,,,and the red light is on at the panels,,,can it be a fuses??? I though of the and brake but my hand brake is on and the light of the hand brake is of on the panel
Old 09-07-2014, 05:00 PM   #4
Tim & Lisa Trempert
What happens when you press and hold down the "auto" button for 5-10 seconds with the power to the panel turned on? I'm assuming you have your engine running?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 09-07-2014, 05:12 PM   #5
Problem fix,,i took out the conection at the back of the panel and re- connect and everything works good now,,,thanks for the support anyway,its appreciate
georgetown, jacks
