Old 05-24-2014, 08:26 AM   #41
Krazymace's Avatar
Originally Posted by Seventh Heaven View Post
Woke up this morning and found the breaker box and our jacks have finally retracted!!! Thank you all for your help..I cannot even express to you how much that was a comfort to have so many people to respond to my problem!!!Attachment 53155
I know exactly how you feel. This is a great forum and I have learned so much using it.
Krazymace is offline   Reply With Quote
Old 05-24-2014, 12:38 PM   #42
Dijoeboss's Avatar
It's all a learning curve! Now you will never forget where that fuse is!! I had this happen to me once as well and Google was my friend!!! Glad you figured it out, I know the stresses of not knowing how to fix something right when it happens!!
Dijoeboss is offline   Reply With Quote
Old 05-24-2014, 01:43 PM   #43
Iggy's Avatar
Originally Posted by Krazymace View Post
Third photo looks like mine iggy.
Glad things are working properly.
Interesting you have two circuit breakers and I have one.
Bottom line is try not to run the pump without being connected to shore power or generator. That way your battery charger is always helping to maintain 12 volts DC. If the voltage in the batteries get low it will hurt the pump motor.
Also try to wait a minute between retracting each slide as well as the leveling system.
This way the motor won't over heat which also causes premature failure.
Have fun!
Old 05-24-2014, 02:11 PM   #44
VinceU's Avatar
Originally Posted by Cornelius View Post
I had a similar problem last week when cold weather caught us. The jacks retracted very slowly, and then failed to operate at all. In addition to what has been mentioned by others here, I found two blown fuses in the metal box under the steps near the batteries. There are about 10 automotive blade style fuses inside this box, and none of them are labeled as to their function.
After topping up the hydraulic fluid (Dexron/Mercon automatic transmission fluid), resetting the black circuit breaker on the chassis frame near the pump, and replacing a blown 5 amp and 15 amp fuse in the box near the batteries, all was well again.
Two questions for the group:
1. Does anyone have a list showing the circuits protected by the fuses in the box near the batteries?
2. Does anyone know the location of the Lippert leveling control module? Lippert says it should be attached to a basement compartment ceiling, but I have not found it. There is a blocked pass through area for slide out power cables and LP hose, that's about the only place left that I can think of. Thanks.Attachment 53143
That computer I believe was under the dash, its sets what is level among other features. Must admit I could never find in in front of the drivers chair, located control panel wire harness and traced it under there also, just too much going on to trace wires.
Old 05-25-2014, 10:26 AM   #45
jojo bamboo's Avatar
Great thread
I think we all learned something
BTW same thing happen to me
I didn't sleep very well that night
but found the breaker the next morning.
What a relief.
jojo bamboo is offline   Reply With Quote
jacks
