Old 06-15-2016, 06:43 PM   #1
CombatYoga's Avatar
Jacks wouldn't retract - got them up
Thanks to this forum, when my jacks wouldn't retract on my '15 GT 270S this past weekend, I knew to look in the battery compartment. I saw the red lever thingy had popped out and I pushed it back down.
When I went back into my rig, all of the lights on the left from top to bottom
were blinking in unison. I pushed and held all 4 arrow buttons, then turned the system on and the jacks retracted fine.
I wonder if I needed to hit the 4 arrow buttons?
At any rate, my question is: Now that I went through this reset process, do I need to recalibrate my jacks?
Thanks!
2015 Georgetown 27S
CombatYoga is offline   Reply With Quote
Old 06-15-2016, 07:54 PM   #2
Jmsx2's Avatar
Thanks!
We had the same problem happen to us in our 328tsf. All I needed to do was reset the circuit breaker (red flag indicator) and everything worked perfect.
No need to hold the four arrow buttons. Glad everything worked out for you.
John & Janine
Pazzo the Maltese
2014 Georgetown 328 TSF
2013 Jeep Wrangler Rubicon (Toad)
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 06-15-2016, 09:17 PM   #3
cawffeeguy's Avatar
Curious I have a 2015 270s also and didn't know about the reset button. (brought used and was never told and forgot to ask). If the reset didn't work - Question...how do you manually raise jacks if they are stuck down???
Cawffeeguy
2015 Georgetown 270s
cawffeeguy is offline   Reply With Quote
Old 06-16-2016, 08:25 AM   #4
Jmsx2's Avatar
Don't quote me on this. I remember reading this in the LCI Owners manual. On our Coach I think you open a valve, use a cordless drill with a screw driver bit to an access paneling on the pump. Depending on which way you run the drill the jacks will retract or extend.
I would suggest find your owners manual or look it up online to verify this procedure.
Good Luck.
John & Janine
Pazzo the Maltese
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 06-16-2016, 09:03 AM   #5
cawffeeguy's Avatar
I'll take a peek around...would anyone have a picture of where this is at?
Cawffeeguy
Old 06-16-2016, 10:36 AM   #6
bubbles's Avatar
This may help if Lippert hydraulic.
File Type: pdf Manual_Override_leveling_slides[1].pdf (940.0 KB, 218 views)
Old 06-16-2016, 04:07 PM   #7
cawffeeguy's Avatar
Thanks Bubbles...I hope we never have to use it but just in case I'm making copies and putting them all over the unit
Cawffeeguy
Old 06-16-2016, 07:13 PM   #8
bubbles's Avatar
So as not to mislead here is another document for Lippert that has a slightly different manual retract procedure that does not reference the blue knurled knob (pages 34/35.
File Type: pdf Lippert Hydraulic Leveling Jacks-Slideouts.2.pdf (2.68 MB, 116 views)
Old 06-16-2016, 10:07 PM   #9
cawffeeguy's Avatar
Thanks so much...
Cawffeeguy
Old 06-21-2016, 08:21 PM   #10
This video helped me do my 364 - really helps having a video.
https://youtu.be/aT925EGb8pA
2016 Georgetown 364TS
2005 Honda Pilot (toad)
Wife, 3 kids, dog
ramseyjacob is offline   Reply With Quote
Old 06-21-2016, 08:27 PM   #11
cawffeeguy's Avatar
You Da Man
Cawffeeguy
Old 06-22-2016, 09:42 AM   #12
CombatYoga's Avatar
Amazingly helpful video - well done!
Wife, 3 kids, dog
Thanks a lot for posting this!
2015 Georgetown 27S
Old 06-22-2016, 04:14 PM   #13
Some really good information.
What is the black and white wire for? In the video he says you need to disconnect it but doesn't say what it's for / why.
carmex is offline   Reply With Quote
jacks
