Old 07-03-2013, 06:02 PM   #1
jeep milage towing
Do not understand how things work w/milage while towing. Was told by RV installer of my Roadmaster Tow system to pull yellow fuse so milage would not register while towing,so thats what I do???????? Will not do it next time and see what Hppens. Thanks for the info,
loryray is offline   Reply With Quote
Old 07-03-2013, 06:32 PM   #2
Wanderluster
OffPavement's Avatar
Not sure which yellow (20a) fuse you are pulling, but it doesn't control the speedometer when towing. I bet the fuse you pull controls the brake lights and here is why you pull it. All supplemental brake systems activate the service brake to stop. Pushing on the brake pedal also activates the brake lamps, but that is where the problem starts. When you are towing, you use the brake, turn, and running lamps of the RV to power the towed vehicle lights,, but when the brake pedal is depressed in the towed vehicle, it cancels out the turn signals if they are on in the RV. That's all it does.
The Road To Paradise Is NOT Paved!
Brian & Margie
www.rv-camping.org
OffPavement is offline   Reply With Quote
Old 08-25-2013, 09:58 AM   #3
tncruiser's Avatar
i towed 2 different jeep wranglers for about 10,000 mile it does NOT add miles and after 2010 you dont need the key in as the steering wheel does not lock
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 08-25-2013, 02:05 PM   #4
You're probably pulling the "M-1" fuse, which is for the brake lights which, when being towed, are activated by the coach. Also, since your transfer case is in nuetral, the transmission is not turning, which means you do not add miles when towing your Jeep.
The above pertains to both the 2012 and 2013 Wrangler Unlimited. Other Jeeps may vary. See your dealer for details.
Michael & Donna
Little Ones Karen & Becky
2012 Georgtown 350TS
Couple of Harley's (When not pulling the Jeep!)
Deland, Fl
Roadglider09 is offline   Reply With Quote
Old 08-27-2013, 10:24 AM   #5
Retired US Army CW4
Tom and Kat's Avatar
What year is your Jeep? All of them are different.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
Old 08-27-2013, 03:45 PM   #6
I have a 2014 and dont pull fuses
fullenw is offline   Reply With Quote
Old 08-28-2013, 12:47 AM   #7
howdy I have a 2012 378ts motorhome I pull a jeep 2012 Rubicon 2 door weights 4200 lbs,i use a ready brute tow bar ready brake system, steering wheel doesn't lock and no fuses to pull, does not add any mileage to jeep. pulls nice. Hope this helps. Pete
petey is offline   Reply With Quote
Old 08-30-2013, 07:48 PM   #8
Los Popes's Avatar
My toad is a 2011 Jeep Wrangler Rubicon 4-door. I have a Roadmaster Sterling All-Terrain tow bar and the Stay-n-Play Duo braking system. I hook up, put the transfer case in neutral, transmission in park, pull the keys, flip the switch on the Stay-n-Play and hit the road. Steering wheel doesn't lock, no fuses to pull, no mileage on Jeep. I keep a driver's log in the RV and log the unregistered miles I put on the Jeep for tire wear, etc.
Bubba & Chiquita + Two Vizslas (Barley and Sophie)
2008 Georgetown 315DS SE LTD
2011 Jeep Wrangler Unlimited Rubicon
Sterling All-Terrain Tow Bar - SMI Stay-In-Play Duo
Do What You Like - Like What You Do!
Los Popes is offline   Reply With Quote
Old 08-30-2013, 11:03 PM   #9
what your doing is correct, but mine has a cable that pulls the brake peddle.no electric. They sure got a lot of good stuff out there today. Pete
