Old 11-09-2015, 01:05 PM   #21
RVnut's Avatar
Can anyone tell me which one of these nipples do what.. Looking for water tank drain?
Name:	tank drain 001.jpg
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 11-09-2015, 02:06 PM   #22
AquaMan's Avatar
One of the 2 blue that are together is the fresh water tank drain, the others are low point drains.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-09-2015, 04:07 PM   #23
RVnut's Avatar
Thanks.. It is to bad the owners manual is to generic for this two of everything set up..
364 Georgetown 2016
in Montana
Old 11-09-2015, 04:50 PM   #24
AquaMan's Avatar
True that! Btw, on mine, the shorter of the 2 blue hoses is the fresh water drain. Checked it out tonight.
Old 11-09-2015, 04:57 PM   #25
RVnut's Avatar
The reason I wanted to know is I wanted to see how much water is left.. I cannot believe we ran out so I want to see how much is left.. I never got to take a shower since we were concerned and coffee was more important... lol.. I know with our old Motorhome we had to put a shut off valve in the vent line cause to much was sloshing out on the way to our camp site.. We were losing a 1/3 of a tank in travel.. Wonder if we are having the same issue
364 Georgetown 2016
in Montana
Old 11-10-2015, 06:54 AM   #26
1st Time RVers
Refrigerator Door issue
T For a Tight Seal
We have residential refrigerator in our 2016 364. Here is a link to an article in the October 2015 Motorhome Magazine: "T for a Tight Fit".
I made one and used it on our last trip. It along with the straps kept the doors for swinging open when items shifted during travel.
Good luck, enjoy!
willwhig is offline   Reply With Quote
Old 11-10-2015, 07:07 AM   #27
AquaMan's Avatar
Originally Posted by willwhig View Post
T For a Tight Seal
Good luck, enjoy!
Thanks for the link! Will be making one of these, and it helps that our last begins with "T", wife will think it's a decoration.
Old 11-10-2015, 08:13 AM   #28
RVnut's Avatar
I am going to make one today.. What did you make yours out of.. I plan to use a soft pine..
364 Georgetown 2016
in Montana
Old 11-10-2015, 09:10 AM   #29
VinceU's Avatar
The problem is mostly you can't put the capacity in. First the 10 gallon water heater is included in the advertised capacity. Next many FR's are plagued with poor venting of the FW tank. The tank will overflow pre maturely an sometimes even siphon more. Contents underway, lots of posts on here to correct it. Some double or nearly so the on board water.
VinceU is online now   Reply With Quote
Old 11-10-2015, 02:01 PM   #30
1st Time RVers
I used a piece of birch plywood
