Old 11-10-2015, 02:09 PM   #31
RVnut's Avatar
Originally Posted by VinceU View Post
The problem is mostly you can't put the capacity in. First the 10 gallon water heater is included in the advertised capacity. Next many FR's are plagued with poor venting of the FW tank. The tank will overflow pre maturely an sometimes even siphon more. Contents underway, lots of posts on here to correct it. Some double or nearly so the on board water.
What should I look under for posts on water capacity.. I dont seem to be getting anywhere
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 11-10-2015, 05:07 PM   #32
RVnut's Avatar
I gather there is only one fresh water tank.. Looking in the long skinny door with both water pumps I see the valve to pull in the antifreeze when winterizing but I also so another valve in front of the forward water pump.. What does it do?? The really need to make a separate manual for these two bathroom models..
364 Georgetown 2016
in Montana
Old 11-10-2015, 08:32 PM   #33
VinceU's Avatar
Check for FW tank venting
FW tank overflow
Georgetown FW tank overflow
Old 11-10-2015, 08:41 PM   #34
RVnut's Avatar
Thanks I will start doing research now
364 Georgetown 2016
in Montana
