Old 06-25-2014, 04:23 PM   #11
Krazymace's Avatar
Only thing I couldn't rule out was the 50 amp cord. Everything between that and exterior plug is fine.
Krazymace is offline   Reply With Quote
Old 08-01-2014, 07:52 PM   #12
Krazymace's Avatar
So I took my coach to the dealer today and described my problem. He said he thinks the owners manual indicates not connecting to 20 amp. I haven't looked, but I think that is BS. I've owned 6 RV's, 30 or 50 amp. Never had a problem connecting to GFI outlet. In this case, nothing in my coach is running and I can't even turn on the main without tripping the GFI. His advice was to replace the GFI with a non GFI. Sounds pretty stupid to me.
Old 08-02-2014, 10:32 AM   #13
Originally Posted by Krazymace View Post
I have a main breaker. As soon as I turn that one on, GFI trips. I used different adapters and extension cord and get the same result. So appears something haywire with my motor home!
Did you turn off all of the sub breakers before you turn on the main breaker?
Paul S. is offline   Reply With Quote
Old 08-02-2014, 10:56 AM   #14
Krazymace's Avatar
Yes.
Old 08-02-2014, 11:43 AM   #15
bend302's Avatar
Have you tried with the generator running?
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is online now   Reply With Quote
Old 08-02-2014, 12:39 PM   #16
Krazymace's Avatar
Bill
Guess I don't understand how running the generator at the same time I'm connected to GFI shore power would give me any answers.
Old 08-02-2014, 01:42 PM   #17
bend302's Avatar
If running the genny with shore power disconnected would tell you if the problem is in the coach or the cable/shore power.
Bill
Old 08-02-2014, 01:44 PM   #18
Tim & Lisa Trempert
For ease of packing, when I'm getting ready to go on a trip, I pull my motorhome out of my garage in my back yard and pull it into my driveway at the front of the house. In the past, I run power to it off a 20 amp outlet. Today, when I connected to power, it trips the GFI to the outlets outside my house. I tried 2 different circuits, same result. Has worked just fine in the past. Works fine when connected to 30 amps in storage. Help!
Make sure you are using 3 prong 20amp extension cord. If it still happens then you likely have a faulty ground connection in the main RV electrical panel or reversed polarity.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-02-2014, 01:50 PM   #19
Krazymace's Avatar
Used good quality extension cords and adapters. Tried it on 3 different GFI circuits. No reversed polarity on any outlet based on my surge protector read. It has to be something internal.
Old 08-02-2014, 01:52 PM   #20
Tim & Lisa Trempert
Bad main breaker in the RV would be my thought.
Tim & Lisa
2011 Georgetown 350
