Old 06-24-2014, 05:26 PM   #1
Krazymace's Avatar
Keep tripping GFI'sq
For ease of packing, when I'm getting ready to go on a trip, I pull my motorhome out of my garage in my back yard and pull it into my driveway at the front of the house. In the past, I run power to it off a 20 amp outlet. Today, when I connected to power, it trips the GFI to the outlets outside my house. I tried 2 different circuits, same result. Has worked just fine in the past. Works fine when connected to 30 amps in storage. Help!
Krazymace is offline   Reply With Quote
Old 06-24-2014, 05:36 PM   #2
BombDoc's Avatar
Originally Posted by Krazymace View Post
For ease of packing, when I'm getting ready to go on a trip, I pull my motorhome out of my garage in my back yard and pull it into my driveway at the front of the house. In the past, I run power to it off a 20 amp outlet. Today, when I connected to power, it trips the GFI to the outlets outside my house. I tried 2 different circuits, same result. Has worked just fine in the past. Help!
This happened to me with on my 5th Wheel a little over a month ago. I eventually figured out that one of the electrical cords that carry power to the slide out motor had become pinched, cut through the outer protection of the wire but did not cut the wire in half. I could use the on board battery power to open the slide, without it being plugged into my GFCI protected house outlet. While the slide was out, I could plug into the GFCI and it would not trip. Microwave stayed on and a mini dehumidifier stayed on. When I pushed the slide button to bring the slide in, all was fine until just about 1 inch from the slide being fully closed. Then the GFCI outlet would trip at the house and the microwave and dehumidifier would shut off. It took me a good hour or so to figure out what was happening. I had the DW run the slide out while I got on the ground and watched the cables. Sure enough, on closing, one was getting pinched and the exposed wire was causing a short, thus tripping the GFCI. Hope this helps.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 06-24-2014, 06:05 PM   #3
Krazymace's Avatar
Put both slides out and then tried connecting power. Same result. Thanks
Old 06-24-2014, 06:12 PM   #4
BombDoc's Avatar
I'm sure someone will be along shortly to offer some suggestions. I could only offer my experience. I did have some folks on here tell me the GFCI are prone to being weak and can do this. Mine were working fine for almost a year, and like you, all of the sudden quit working. I tried several outside the house and each did the same thing. All I can say is something in your unit is causing a short. Once I found my problem, I haven't had an issue with the GFCI's. If you are trying to rule out the outlet, plug something else in to it and see if it does the same thing. Sorry I can't offer more options.
2013 Sabre 32RCTS-6
Old 06-24-2014, 06:17 PM   #5
Krazymace's Avatar
Thanks Bombdoc. I've never had this problem before. I, like you, have tried everything. The outlet is good. It's going to the dealer in a couple of weeks for some warranty work. I'll let them figure it out.
Old 06-24-2014, 06:26 PM   #6
VinceU's Avatar
Start by opening all of your a/c circuit breakers, all of them. One circuit may have a polarity fault. If the shore power stays connected try closing one at a time.
If that doesn't get it may have a fault in the shore power cord or extension cord you're using.
Old 06-24-2014, 07:22 PM   #7
Krazymace's Avatar
I have a main breaker. As soon as I turn that one on, GFI trips. I used different adapters and extension cord and get the same result. So appears something haywire with my motor home!
Old 06-25-2014, 03:04 PM   #8
Tim & Lisa Trempert
Make sure your water heater is not on electric mode. That pulls quite a bit of current. Turn all your individual breakers off in the RV and your main breaker on and then plug it in and then turn the breakers on one by one until you find the one that trips the breaker.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-25-2014, 03:38 PM   #9
Krazymace's Avatar
Tried that. If the main breaker is on and all other breakers are off, GFI trips. Are there any breakers other than those in the panel?
Old 06-25-2014, 04:04 PM   #10
KMP44's Avatar
Could be a short before the breaker panel - either your cord (but sounds like you already checked that) or the wiring between the cord and the panel in the MH.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
