Old 06-26-2016, 12:03 PM   #1
RVnut's Avatar
King Jack Power Antenna
It seems our king jack power antenna for over the air signals is lacking power. The green power light does not come on. Has anyone else experienced this problem?
RVnut is offline   Reply With Quote
Old 06-30-2016, 09:43 AM   #2
RVnut's Avatar
Any ideas as to why we have no power to the antenna.. None of the little dots light up to show how the signal is doing and we have the switch up in the front on Antenna mode
364 Georgetown 2016
in Montana
Old 06-30-2016, 10:07 AM   #3
bubbles's Avatar
The dots will not illuminate if there is no power to the antenna and sounds like that is the case. You may have a blown fuse for the antenna power booster panel (where the green power lite is) but I do not know where your fuse would be located. Someone with an identical unit should chime in.
Old 06-30-2016, 10:42 AM   #4
RVnut's Avatar
Thanks.. I guess the search is on when I have time.. We have 5 TV's and we hardly use them but we did notice this problem and would like to have everything working before one year in November
364 Georgetown 2016
in Montana
Old 07-01-2016, 03:25 PM   #5
tilap's Avatar
Same happened to me fuse is under the steps.
tilap is offline   Reply With Quote
Old 07-01-2016, 04:30 PM   #6
RVnut's Avatar
thanks I will look after it cools down.. I see tons of inline fuses all around the batteries next to the steps on our 364
364 Georgetown 2016
in Montana
Old 07-01-2016, 05:33 PM   #7
bubbles's Avatar
If the fuse is located under your steps it will most likely be inside the battery control center. Remove the cover and there will be a row of several fuses. If not there it might be located in the fuse panel located to the left of the brake pedal. This may help:
Old 07-01-2016, 06:52 PM   #8
tilap's Avatar
It is in battery control center box
antenna, power
