Old 06-22-2016, 01:55 PM   #11
Originally Posted by ArmyW4 View Post
Thanks - looks like I'll be making a call to FR later today!!!! we're well outside of warranty unfortunately.
You can pull the rubber cover off of the actuator. When you pull it off you'll see the two white plastic buttons that activate the spray and stream. Work them back and forth a few times to clear out any gunk and replace the rubber cover. Should work OK after that.
didn't even think of pulling off the rubber cover - I'll have to check that out and try it this weekend.....!
I love this forum.
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 06-23-2016, 05:59 AM   #12
Wolverine 1945's Avatar
I love this forum.
Garren
If you take it apart and clean it,,, which I am betting will fix it,,, be sure you know how it goes back together !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-23-2016, 06:17 AM   #13
LittlePM's Avatar
And here all this time I thought I was special, I guess not. The problem has gotten worst over the last several months.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 06-23-2016, 06:30 AM   #14
Maybe that is because it has gotten dirtier ???
LOL !!!
Old 06-24-2016, 10:07 PM   #15
Originally Posted by kenkaiser View Post
Had the same problem on my Gtown. Put my hand over the output end of the spray head to block the water flow and pushed the buttons that must have dislodged the mater clogging the valve assembly. Ours now works as advertized.
So, tried this little trick tonight.....I stuck my hand flat against the base and had my husband turn on the water and push the buttons....after looking at me like I was insane (always love that ) and fully expecting a shower in the kitchen.....it worked! He was like "I'll be damned".
Forest river forums strikes again!
Am still waiting to hear from Kevin, he needed some specifics and was looking into it. It's too bad it's not easy to take apart.....
Thanks again!
Garren
