Old 06-19-2016, 12:51 AM   #1
Kitchen sprayer will not flip back and forth
Hi
Haven't seen this problem before, but our sprayer is permanently in shower mode, we've had a harder and harder time flipping it back to stream, and it's finally not working. Anyone else seen this before, and any suggestions? I can unscrew the sprayer but still can't get the button to push.
Picture attached
Thanks!
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 06-19-2016, 08:19 AM   #2
You could try soaking it in CLR , it might have hard water build up keeping it from moving.
revflyer is offline   Reply With Quote
Old 06-19-2016, 12:32 PM   #3
tilap's Avatar
We had the same thing happened after a year. Got it replaced under warranty.
Denis, Forest river Georgetown XL 377 2015, towing a 2014 Ford Explorer XL
tilap is offline   Reply With Quote
Old 06-20-2016, 01:48 PM   #4
Thanks - looks like I'll be making a call to FR later today!!!! we're well outside of warranty unfortunately.....
Old 06-21-2016, 02:17 PM   #5
US Army Retired
ArmyW4's Avatar
You can pull the rubber cover off of the actuator. When you pull it off you'll see the two white plastic buttons that activate the spray and stream. Work them back and forth a few times to clear out any gunk and replace the rubber cover. Should work OK after that.
ArmyW4 is offline   Reply With Quote
Old 06-21-2016, 02:45 PM   #6
NMWildcat's Avatar
If you are out of warranty anyway... just go to Lowes or Home Depot and replace the whole faucet. You can spend as much or as little as you want.
We are on our 5th RV and one of the first things we do is replace all the cheap faucets.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-21-2016, 03:45 PM   #7
Had the same problem on my Gtown. Put my hand over the output end of the spray head to block the water flow and pushed the buttons that must have dislodged the mater clogging the valve assembly. Ours now works as advertized.
kenkaiser is offline   Reply With Quote
Old 06-22-2016, 06:18 AM   #8
Wolverine 1945's Avatar
Our kitchen faucet @ home is totally different than your faucet,,, but I have to take ours apart every 2 or 3 mounts and clean it,,, and apply a small amount of Super Lub !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-22-2016, 01:50 PM   #9
Will have to try that this weekend......!
Old 06-22-2016, 01:53 PM   #10
Yeah....that's what we were thinking - I was hoping to avoid having to pull out the old and replace - but depending on the answer from Kevin @ FR we may go that route. It's just so much easier to just unscrew the head only vs replacing the whole thing.....
I did hear back from him this morning - of course, I hadn't included my VIN for him to work on it, so I sent it back and am waiting for an update.
More as I hear it.
Garren
