Old 05-08-2016, 04:31 PM   #1
Moorio's Avatar
Kwickee steps
Does anyone know the proper part number for the correct Lippert replacement step. They installed a Kwikee 3 step but it only has a 7&3/4" top run and bareley an 8"run on the rest. Th Lippert steps had a 9" run. Any help would be much appreciated
2011 Gergetown 378 TS XL on a Workhorse W22 chassis
Toad is a 2014 Chevy Cruze RS
Moorio is offline   Reply With Quote
Old 05-08-2016, 04:37 PM   #2
fonzie's Avatar
This might help you figure it out.......
RV Steps, Step Accessories and Replacement Parts
Fonzie
Old 05-08-2016, 05:40 PM   #3
bubbles's Avatar
Series 25 step. Part number; 902509000. This is for my 378 on the Ford chassis.
bubbles is online now   Reply With Quote
Old 05-08-2016, 10:48 PM   #4
Moorio's Avatar
Wrong steps
They put in part #902309025 which is an 8" rise and a 8" run. They should have put in part # 902509025 which is an 8" rise and a 9" run. They got together the service writer, the parts man, and the technician all just to pick the wrong part for the job. Do we now know why they charge $149.00 per hour. Because they are totally incompetent
Old 05-09-2016, 06:41 AM   #5
bubbles's Avatar
The 902509025 and 902509000 are identical series 25 steps. The mounting bolt pattern for the series 23 that was installed is not the same as the series 25 and an adjustment had to be done. This misalignment should have raised a flag with the technician to take another look at the steps being installed especially since these steps have been an issue forever and numerous swap outs have taken place.
Old 05-09-2016, 09:35 AM   #6
Moorio's Avatar
Mounting point changes
Yes they had to make a new mounting bracket about 4" up from the old one. it took about ten minutes to find the right one on my own.
Old 05-09-2016, 06:08 PM   #7
Moorio's Avatar
Phone number
Does anyone know the phone # for Kwikee or Lippert? I keep getting Kwikee systems and thats not it. Found it
Old 05-21-2016, 04:30 PM   #8
Moorio's Avatar
6 weeks later
Now why couldn't they do this the first time. They have finally installed the right steps on my coach but when they in stalled the wrong ones they changed the mounting points. Well the new steps have a different bolt pattern. Guess what they did? They welded it to the mounting point and then forgot to prime and paint the welds.
