Originally Posted by teamgl
Nice work!
How did you cut the 6" hole in the RV? Jigsaw?
We are contemplating this type of modification, but will use a marine type hatch and the dirty clothes will be stored in the front of our Flagstaff M/L 23LB.
Other part of problem, very small turning radius. I first used a 1.5" hole sale to get floor composition. Next I used a 18,000 rpm high speed saw with a 2" head (guide). Similar to Dremel tool but larger and more power.
Floor is vinyl, 7/16 glued comp board, bottom fibre woven mat weather proofing about .010" glued to 1/8 Luan, in-between is compressed styrofoam for a total of 3.25". Careful, there are steel square tubing stiffeners inside this sandwich. Well worth it.
