Old 04-06-2016, 02:48 PM   #1
Kanadian Kamper
kenandterry's Avatar
LCI Electronic leveling panel flashing
2010 Georgetown 330TS with Lippert leveling system. Getting ready to head North after hiding in Florida.
All slides have been retracted in. Pushed the "Retract" button for the hydraulic stand levelers. All jacks have been visually checked and ARE retracted.
The leveling panel is flashing all the following lights simultaneously:
WAIT
JACKS DOWN
LOW VOLTAGE
ENGAGE PARK BRAKE
EXCESS ANGLE
I did find the main 100 AMP breaker was tripped, but have reset it.
Even holding the ON/OFF button does nothing.
Is there a master reset program for "rebooting the control panel?"
Thanks.....in waiting
Ken and Terry
kenandterry is offline   Reply With Quote
Old 04-06-2016, 05:04 PM   #2
There is a way to reset the panel by pushing a series of the buttons similar to re-calibrating the auto level, as I recall. Your best bet is probably to call LCI at (574) 537-8900 and get them to tell you. I think I have a manual in our coach that the dealer gave us when we had a total malfunction, but I'm not at the coach.
Good luck!
Steve
swlovett is offline   Reply With Quote
Old 04-06-2016, 05:17 PM   #3
Here are a few documents on the LCI Leveling system. Hope they help!
File Type: pdf LCI_Motorized_Leveling_Owner's_Manual.pdf (3.12 MB, 16218 views)
Wrenchkid is offline   Reply With Quote
Old 04-06-2016, 05:40 PM   #4
LCI pad
Push all 4 diamond shaped pad at the same time
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 04-06-2016, 08:21 PM   #5
Kanadian Kamper
Thanks Don. Pushing all 4 diamonds reset things. All seems well now.
Guess things just needed to wake up after being here awhile.
Old 04-06-2016, 11:30 PM   #6
Krazymace's Avatar
I've had to reset mine several times.
Krazymace is offline   Reply With Quote
Old 04-07-2016, 01:22 PM   #7
We had the same problem with our 2006. Same thing fixed it too. Thanks for the PDFs Wrenchkid.
Caretti is offline   Reply With Quote
Old 04-07-2016, 02:48 PM   #8
If your battery drops below a certain voltage, it will start all the lights blinking. The you have to wait about 5 mins. and have 12.8 volts, and do the reset, as described in KenandTerry's post.
badge2283 is offline   Reply With Quote
Old 06-26-2018, 09:13 AM   #9
Good thread and information. After a 6 hour road trip we tried to set the leveling Jacks and the front two would go down and pop the circuit breaker. On the second try the lights started flashing after I reset the CB again. The slides worked but not the jacks. So we slept on an angle that night. When I woke up in the morning with a clear head I searched the forum and presto magic there's the answer. The reset fixed the flashing lights. Also found that my batteries were too old and damaged to hold a decent charge. That's what was popping the CB.
Coleman Tent, 2001 Coleman Pop-up, 2006 Fleetwood Pioneer 280BH. 2017 Coleman Lantern 300TQ Toy Hauler, current home away from home: 2008 Forest River Georgetown 373DS.
Trickdog is offline   Reply With Quote
Old 06-29-2018, 09:31 AM   #10
On the same topic. I was poking around under my camper and noticed 2 out of my 4 hydraulic lines were resting on sharp edges at the jack. One already has a nick in it from vibrating and being zip tied to a sharp edge of the chassis. Might be something to check......
2017 Georgetown GT3 31B3
N Little Rock AR
bclinton is offline   Reply With Quote
Old 06-29-2018, 09:58 AM   #11
bubbles's Avatar
Assuming you had the engine running when levelling to supply supplemental voltage from the alternator. Of course slides will not work with ignition on.
Old 06-29-2018, 12:03 PM   #12
miked11272's Avatar
I had the same issue with my 2009, I replaced the house batteries and haven’t had the problem since.
miked11272 is offline   Reply With Quote
leveling
