Old 05-25-2016, 01:43 PM   #1
LCI level
HELP..............2010 G/ town 374ts with LCI levelers. Spoke w/ Lippert and they feel I am not getting power to the keypad??? They said find the control module for the levelors and work from there... WHERE IS THIS MODULE???? no response from F.River and desperate to correct as we are trying to take a short trip soon. ANY help is appreciated..........................
belsy is offline   Reply With Quote
Old 05-25-2016, 01:56 PM   #2
Iggy's Avatar
I think the fuse that powers that is from the fuse panel to the lower left of the steering wheel.
I have no idea which one so you may have to check them all.
Please let us know what fuse it is so you can help others.
ID:	108995   Click image for larger version
ID:	108996   Click image for larger version
Old 05-25-2016, 02:11 PM   #3
I will look
Going in!!! ...............if you don't hear from me in 24 hrs. send help to pry me out! This is a tight area and I may fall asleep while researching??? If I am successful I will let you know.
Old 05-25-2016, 02:33 PM   #4
bubbles's Avatar
Just a thought. System may be in timed out mode and can be reset by switching ignition to off and then back to run.
Old 05-26-2016, 12:20 PM   #5
Lippert level
Fuse # 38 gives power to system, control module is around the pump area mounted on floor (access from under the coach) .....
