Old 10-09-2011, 09:58 AM   #1
SEAYALL's Avatar
LCI leveling
Greetings
got a 2012 378, after sitting a few days with levelers retracted i have noticed right front leveler drops down a few inches, i have retracted several times to be sure an it does come down on its own, i have also noticed on other rigs they got two big springs on there pads to keep this from happening, can someone enlighten me, an are those springs an after market thing i might be able to find an install for peace of mind .I have know leaks expect for tiny drip on cap of reservoir like everyone else an apparently no fix for that, but reservoir is at level its spose to be,not a hydraulics man, but maybe i'd guess a check valve or something in that cylinder not right ???? thanks
SEAYALL is offline   Reply With Quote
Old 10-10-2011, 03:10 PM   #2
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by Harleydriven View Post
Greetings
They are a different brand. HWI made in Iowa. LCI hasn't cornered the market on leveler problems. HWI has their share too. I have several friends that have had problems with their HWI levelers. But both companies are pretty good at helping you with them. What you probably have is a leaking valve. LCI has oil on both sides of the piston, so it powers up and down both. Its a two way cylinder. HWI uses springs to retract because its a one way cylinder.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 10-10-2011, 03:21 PM   #3
SEAYALL's Avatar
Thanks, looks like off to the dealer .. appreciate it ...
