Old 03-02-2016, 08:49 PM   #11
VinceU's Avatar
Originally Posted by DuncanM View Post
I have the same MH model and year. Had same problem and have posted about it on here. Do a search and you should find it. There is a recall on the wiring harness. To get the jacks to work until you can get the harness replaced, pull the black and white 2 wire plug out of the side of the motor. Then you can cycle the motor to retract all jacks
Originally Posted by Pauline View Post
Thanks VinceU, Would I be able to drive MH if I can't fix the problem. (if I disconnect the battery to the pump). I may have to have someone else repair this. Does replacing the switch sound like the right thing to do?
If you search for a thread called Hydraulic horrors dtd. 5/8/12 posts 1-11 all history and repair are outlined with photos of the failed parts are displayed. It was complex then but others have had the same problem.
Old 03-03-2016, 06:06 AM   #12
Thanks all for your help. It may be a few days before I can get to it. But Thanks all the same.
Pauline is offline   Reply With Quote
Old 03-03-2016, 10:41 AM   #13
I have a 2014 351. I can't find that previous post about the jacks recall. Can someone post a link or something if they find it?
Preadus is offline   Reply With Quote
Old 03-03-2016, 11:41 AM   #14
Starboard's Avatar
It's the wiring harness, there's a recall. You need to contact LCI and they'll tell you how to manually raise them and then will ship you a new harness. Takes 30 mins to replace it, it's not really a big deal.
Starboard is offline   Reply With Quote
leveling
