Leak problem
Ok, I have a leak I need help with. On my Georgetown, as you are looking at the hot water heater, there is a leak coming from the tank below it. Which tank is that?
I've had to shut water off to the RV to stop the leak. Nothing else will work. This seems to be some kind of pressure problem from the outside water connection. Has anyone had this problem or know what's it from?
Not too long ago, I was flushing the tanks after draining both black and gray tanks. I thought I had both tanks open but had left the black tank closed. I realized what I had done and went back to open the black tank.
I think my leak could be caused from what happened but I'm not real sure. Anyone have any ideas? Is this an expensive repair for a technician to fix?
