Old 05-19-2016, 07:07 AM   #1
Leak Under Coach
When I went to start my MH yesterday, I noticed something had leaked underneath the center storage area. Not sure what it could be. Are you able to tell by the location in the pics? I just want to make sure I can drive it safely (60 miles) for servicing tomorrow. Thanks in advance!
ID:	108297   Click image for larger version
ID:	108298   Click image for larger version
lludvig is offline   Reply With Quote
Old 05-19-2016, 08:15 AM   #2
It could be just water, I saw the same thing on mine. It was coming from where the exhaust pipe connects to the catalytic converter. There was no smell to it, so mine was just water.
revflyer is offline   Reply With Quote
Old 05-19-2016, 11:35 AM   #3
Happily Retired Member
Right under the muffler rear more than likely just water from exhaust condensation. If you look at the rear lower muffler area you will see a small drain hole for that purpose. Helps the muffler last longer.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 05-19-2016, 08:20 PM   #4
Water
Thanks for replies. It was no longer there when I went to check it out this morning.
Old 05-22-2016, 12:46 AM   #5
ramair's Avatar
X3 on the muffler and cat area not a problem just condensation.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
leak
