Old 07-01-2011, 05:54 PM   #11
I also have a 2011 cedar creek that my lipper self leveling system worked fine at first, but now it has stopped and I noticed a fluid on the rear jack. Dealer is to busy. Any help would be nice.
Mickymell is offline   Reply With Quote
Old 07-28-2011, 11:31 PM   #12
Burr Rabbit's Avatar
Just wanted to post bak an update. Donn above was correct, simple O ring seems to have fixed it and boy am I glad. Everything is working well and no leaks to date. This is a great forum and appreciate everyone's feedback, especially donn. Peace.
Burr Rabbit is offline   Reply With Quote
Old 07-29-2011, 03:25 PM   #13
Burr Rabbit, Glad to hear your leak is fixed. I had mine at the dealer for my leak mentioned earlier. Seems to be fixed too. It was leaking at threads on the nipple that connects a pressure relief valve. Hope it stays fixed!
ohiobill is offline   Reply With Quote
Old 07-29-2011, 05:10 PM   #14
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
This is an older post but there is some interesting information about using permatex.
Hydraulic Leak
dimurrrw is offline   Reply With Quote
Old 08-14-2011, 09:59 PM   #15
08 Georgetown SE 350ts Lippert Pump leak
I have the same problem - Pump assembly leaks fluid underneath compartment to ground - Decided to remove entire assembly to identify source of leak - Marked each hose and removed assemlby from compartment - Note - relieve pressure 1st or you will end up covered in ATF as I did - Discovered 2 problems - 2 very small Orings were hard and brittle that connects valve body to pump and Oring between pump and fluid reservoir seems undersized - Will replace all Orings - Confident this is a fix - Many posts from others describing Oring issues between pump and reservoir - Was afraid ATF would get in the pump motor and stop working at the worst possible time - The motor is sealed and unlikely to get fluid intrusion - Hope this helps
cjmcvay is offline   Reply With Quote
Old 08-19-2011, 04:21 PM   #16
jmduc's Avatar
How do you relieve the pressure on the system
THANKS
jmduc is offline   Reply With Quote
