Old 12-02-2013, 04:28 PM   #1
Newellri's Avatar
Leaky hydraulic hose
Bummer, found a leaky hose today, motorhome is 2 1/2 years old hope they cover it under warranty. I plan to go to TX in 3 weeks. Has any one replaced one themselves? How hard is it replace. The Des Moines RV dealer is swamped with work!
Newellri is offline   Reply With Quote
Old 12-02-2013, 05:00 PM   #2
Ford Idaho's Avatar
If you can get to it take it off and go to a farm supply outfit and have them make one.
I have replaced hyd hoses before.
Be sure the pressure is off and that you have hyd fluid to replace what you have lost.
How long it will take depends on your skill level.
Still betting it will take less than the dealer.
Old 12-02-2013, 05:00 PM   #3
undr60's Avatar
I had mine replaced at Camping World. I had the orange hoses with bubbles. I would contact FR in advance to see if the are willing to cover the replacement. I have a 2011 coach. Mine was still in warranty. Search the forums for orange hoses for other experiences.
undr60 is offline   Reply With Quote
Old 12-02-2013, 07:03 PM   #4
Glad we went with the 7 year bumper to bumper for 1200 bucks.
Where is it leaking from? Could be a little lose.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 12-02-2013, 09:23 PM   #5
Newellri's Avatar
I checked first and not loose, I replaced hoses all the time on farm machinery. I just wondered how easily it could be gotten to. I called dealer to see if still could be done under warranty. The are way behind and I may do it myself so I can leave for TX by the 20 th.
Old 12-05-2013, 07:32 PM   #6
Newellri, the orange hydraulic hoses in the 2011&12s, maybe later are infamous for developing blisters, then leaks. FR has been very good about covering the replacement of those hoses. I had one about three months ago go bad and they were willing to cover it, but I didn't have time to wait, so my dealer did it under the extended warranty. They replaced all of mine except for two about a year after I got it. Naturally one of those they didn't replace is the one that started leaking. Good luck.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 12-05-2013, 08:21 PM   #7
Newellri's Avatar
This one does not seem to have bubbles just weeping, the dealer is checking with factory. The real problem we want to leave for TX soon! Thanks everyone for help
Old 12-05-2013, 09:00 PM   #8
jojo bamboo's Avatar
Sounds like my hoses (2007 373)
I'de like to know how you make-out with the factory
jojo bamboo is offline   Reply With Quote
Old 12-05-2013, 09:44 PM   #9
Dijoeboss's Avatar
If you can get the hose off and take it to a hydraulic shop, they can make you a hose with new fittings quick! Then it's just a reinstall and done. Try to find some caps and cap the ports where the hose connections are removed ( cylinder / pump ) , that will help slow the loss of fluid.
Dijoeboss is offline   Reply With Quote
Old 12-05-2013, 10:51 PM   #10
VinceU's Avatar
Biggest problem is hose routing. I noted a couple over the fuel tank, coiled and secured up there. Scope out the bad hose and make sure you can access it.
hydraulic
