Old 08-12-2016, 10:34 AM   #1
Leaky Hydraulic Pump
Ok I know this isn't a new topic, but I searched on this forum leaking hydraulic pump and really got confused by some of the return searches. Just recently I've noticed that when we open/close a slide while our rig sits in the drive I'll have a small spot of fluid under the pump where fluid leaks out. It appears to come from a large nut on the side of the pump that loosens and than leaks. I tighten the nut but it seems to be getting worse. My search returned many types of leaks with the scariest being fluid getting into the pump body itself and frying the pump. I'm not a mechanic like some have posted but trying to hopefully get some direction on what I'm experiencing. Leaving on another trip Wednesday so I am trying to get some ideas to address this issue in detail when we return.
sherman12
2011 Georgetown 330TS
RAV4 on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 08-12-2016, 12:01 PM   #2
There is most likely an o ring under there that is bad . Can you post a picture of that large nut?
lbrunning is offline   Reply With Quote
Old 08-12-2016, 03:15 PM   #3
lbrunner I'll try to get a pic posted. I've read about " o rings" but don't really know where to look. With three slide outs and the jacks there are eleven hydraulic line in/outs and no clear view of anywhere else it could be leaking than the mentioned nut,
sherman12
Old 08-12-2016, 03:42 PM   #4
Here are a couple/three pictures
ID:	117031   Click image for larger version
ID:	117032   Click image for larger version
sherman12
Old 08-12-2016, 04:39 PM   #5
I would bet that there is an o ring under that nut if you take it out be careful there might be a small spring and or ball under it. Looks like it is an o ring boss port (orb) witch takes a special o ring. One other thing that will help to find a leak that is hard to see is to clean and dry the area , I use brakekleen and blow dry with compressed air then place paper towels around the suspected area run it and see where the paper towels are wet
Old 08-12-2016, 04:59 PM   #6
toslow's Avatar
that also looks like a relieve valve so when you take it out make sure there isn't a spring in the hole that flies out.
haven a blast
toslow is offline   Reply With Quote
Old 08-12-2016, 06:47 PM   #7
SS396CV's Avatar
I am wondering if you have a too high pressure situation, where the pressure relief valve is doing it's job. I believe you can search for the repair manuals on-line for your particular model
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 08-12-2016, 09:49 PM   #8
Dijoeboss's Avatar
Like others have said, I would take that nut out slowly and be sure to catch any spring/ ball that may be under it, take that fitting to a hydraulic hose builder type shop and get a hydraulic o'ring to replace it with.
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 08-13-2016, 10:33 AM   #9
This appears to be my unit. Can't find out though from Lippert Owners Manuel what the "nut" is. Notice the extension piece on the new unit.
sherman12
Old 08-13-2016, 10:41 AM   #10
SeaDog's Avatar
If you are going to be removing nuts and such ensure that you have all pressure off the system, these units work under high pressure and jacks and other items hare held in position by that pressure. JMHO
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
hydraulic, leak, pump
