Old 07-19-2016, 10:26 AM   #1
Iggy's Avatar
Learn something new today
After years of owning my Georgetown I learned something new today.
Did you know that the your front yellow marker lights are also turn signals?
Yes the marker lights next to your side cameras also flash to tell cars on your side that you are planning a turn, They are multi function lights.
I didn't know that until recently.
Old 07-19-2016, 11:05 AM   #2
SS396CV's Avatar
Iggy, I assume you checked both sides to see if they flash. On mine the left side flashed the right didn't. What I found is that Forest River cut the turn signal wire to the lamp and ran a ground from the lamp to the frame instead. The marker light worked the turn signal didn't.
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 07-19-2016, 12:10 PM   #3
Tailwind's Avatar
I didn't know that either! I think the mid-coach and rear marker lights should also flash. Fronts alone can be hard to see in bright sunlight from much more than 1/4 if the way back from them.
2012 F-250
Flagstaff 8528IKWS
Tailwind is offline   Reply With Quote
Old 07-19-2016, 06:00 PM   #4
Iggy's Avatar
Both flash if I turn right or left on the specific side. Your should both work that way.
If you have one not flashing check the socket. May be corroded as it was on Ramairs rig.
Too much water over time corroded the bulb socket connections.
Old 07-20-2016, 10:44 AM   #5
SS396CV's Avatar
Iggy, that's how I found out the lamp was wired wrong. The bulb was a little corroded and the right side view camera would activate when I turned on the headlights. When fixing that problem I found the wiring issue causing the bulb not to flash. Sounds like yours is wired correctly.
Old 07-20-2016, 11:16 AM   #6
cjd10's Avatar
Did not know this. I'll have to check it out
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 07-20-2016, 02:13 PM   #7
Cool! Thanks Iggy, I'll check it out. We only stop learning when we're dead or think we know it all. And you've been a great tutor on this forum.
FroggyRon (Ron)
2014 Forest River Georgetown XL 377
2014 Jeep Cherokee Latitude 4X4 toad
FroggyRon is offline   Reply With Quote
