09-17-2018, 06:38 PM
LED ceiling light help
The bulb strip is burn out on one of my lights. I cannot find the same unit nor just the bulb anywhere. Attached are the pictures I don't have a make or model on the unit but I did have a part number for the bull strip but no joy finding it. Anyone had to replace one before without having to mix match?
This is off a 2015 351 ceiling light.
"MACK"
2006 F350 6.0 Diesel 3.73 4x4 FX4 "sold"
2010 Forest River Signature Ultra Lite "sold"
2010 Keystone Laredo 310RE 5th wheel "sold"
2015 Georgetown 351 "sold"
2016 Coachmen Sportscoach 404RB
09-19-2018, 09:39 AM
I have a similar unit, I plan to un-solder the existing LED lights and add my own section of LED lights. I connected the LED strip to the existing positive and negative connections and the strip light up. The strip is not expensive and you will be able to fix many lights as they go bad.
2018 Forest River Georgetown model 31L5
Flat towing a 2019 Chevy Spark
09-19-2018, 09:45 AM
Easy fix, remove and solder new LED light.
https://www.ebay.com/itm/10x-High-Po...1XkJVw&vxp=mtr is what I would use.
Lots of basic solder videos on youtube to learn how to do it. It isn't hard and even I can do it. You can get a soldering iron for about $5 from Harbor Freight.
09-19-2018, 09:16 PM
Thanks yea I can solder just was trying to find a similar led strip so they’ll match.
"MACK"
09-20-2018, 08:14 AM
Ceiling lights
Hello, I had the same problem and found these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 They're the same size, but the white bezels are a little more white then the originals. The mounting holes are in a different spot too. I have the replacements for awhile now, and they have been working great. Hope this helps - Joe
09-20-2018, 08:27 AM
Trance --
How bright are these LEDs? I purchased some disk-shaped LEDs that directly plug into the 921-style sockets in the ceiling lights and found them to be much dimmer than the automobile 921 lights originally there. Found some very bright automotive lights that work but are something like $15 per fixture.
These are what I have and they're not bright enough. Only 24 LEDs per disk so I imagine the 48 LED panels are better.
-- Chuck
09-20-2018, 01:28 PM
I have the exact same fixtures in our 2016 2304KS the fixture that I added in front of the medicine cabinet was purchased from F R early in 2016. The L E D'sfailed last year, so I replaced the L E D's with my own peal and stick mounted L E D's, as Mac did. However, my replacements were White and not the softer yellow like the original. My wife didn't like the look. After trying to source them on line, Camping World and a local RV store, I found exact replacements at an RV salvage yard, just down the road a bit from the Goshen fair grounds, when we were at the FROG rally in August. $7.00 each. I purchased 4 of them. Replaced the bathroom fixture, added one over the control board at the entry door and will add the other 2 to the bottom of the cabinets next to the Murphy bed.
I wish I had bought more, just for spares.
So, I guess if you are near Indiana, that would be the place to go.
09-20-2018, 05:23 PM
This is off a 2015 351 ceiling light. Attachment 186822
Attachment 186823
Try contacting Kelli Bonnema at Command Electronics. She was a great help for my lighting. Tell her Dave Jones sent you, (might cost you more )
kelli@commandelectronics.com
Command Electronics
Cuban Crisis Vet
2017 Forest River SunSeeker 3050S
Ford 450 Super Duty
Just me and the Wife
09-20-2018, 05:34 PM
New LED bulbs in liew of 921 et al
Roll over image to zoom in
20x Super Bright 921 194 T10 LED Bulb, Warm White 12V 24-SMD Wedge Lamp For Iandscaping Boat RV Trailer Camper Motorhome Ceiling Dome Interior Lights (Pack of 20)
Price: $22.86 Free Shipping for Prime Members
09-20-2018, 06:47 PM
Attachment 186823
I had the same lights fail me. I replace six ceiling ligths with AutoEC LED Dome Light, 2 Color Mode 12V LED RV Ceiling Dome Light Fixture. Three on the ceiling in the living room. I like my new lights because they are both white & warm.
I also installed two MICTUNING 2 Pack 12V LED RV Ceiling Light Fixture, 2 Color Mode with Switch over the sink & table. They have a three position switch for White-Off-Warm.
Both lights are larger than the factory lights.
09-20-2018, 06:54 PM
LED help
I have several of these in my TT. Can't figure out how to remove the cover. Advice?
09-20-2018, 07:47 PM
Pry up on the side notches.
09-20-2018, 08:23 PM
Exactly as mentioned above... unsolder old LED and solder in what you want. I even removed an LED that needed a little more light output.
Agree that finding exact replacement fixtures and some LED light bulbs only available with that fixture.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
09-24-2018, 04:03 PM
Following this for any source for replacement light fixtures.
McCormickJim
2017 GT 31L5
09-25-2018, 09:55 AM
I'm not seeing any need for replacing the fixtures as long as I can find 921-pin LEDs that are bright enough. The 48 diode versions should be here soon and I'll try them. Enough diode sets to replace all my 921 bulbs for less than the price of a replacement fixture.
-- Chuck
09-25-2018, 10:20 AM
Erinn
Did you look on Amazon?
https://www.amazon.com/s?k=LED+repla...f=nb_sb_noss_2
I replaced every single bulb (18!) in our old motor home (2013 Thor Chateau), for less than $20 (swapped the old ones for LEDs).
Hope this helps & good luck!
09-25-2018, 03:16 PM
There are some fixture makers who think everything should be proprietary and throw away. In that case take the fixture and decide what LED you want and do some solder work. LED fixtures should all be designed to allow bulb to be changed instead of replacing the whole fixture.
