Old 03-28-2016, 06:37 AM   #11
Wildland Firefighter
No...not at all. They fit perfectly. Same screw holes. No fuss. I just had to figure out the wire colors with a common tester and wahlah.
Gordon and Dawn is offline   Reply With Quote
Old 03-28-2016, 11:39 PM   #12
And by the way... if anyone gives it a try, My 09 357qs tail light wires are BROWN...BLACK...and BLUE. The wires on the light are RED...WHITE...and BLACK. And so it's Coach BLACK to Light WHITE...Coach BROWN to Light BLACK...Coach BLUE to Light RED. I hope that will help. At least that is what they were on mine.
Old 03-28-2016, 11:51 PM   #13
B47
Originally Posted by 1A Camper View Post
I was talking to a truck driver and he hate the LED lights ( brake/turn ) on the rear of his trailers. He said all the new trailer come with LED lights, he hoping they will do back to the old lights on the rear of the trailers. It seem that when it is snowing the LED do not get hot and the snow does not melt off them like the old lights did and it is a ticket when he pull into a weight station if they are cover with snow.
I have heard the stories about the "old style" lights not melting snow. I find it hard to believe that a 12 volt bulb or even two 12 volt bulbs in one assembly can generate enough heat to melt snow on the lens.
Old 03-29-2016, 01:35 AM   #14
ASk someone who has ever tried to change a 1157 Bulb while it is lit! Burn Baby Burn! All of the Plastic overhead lights that have White housing that have Brown Burnt areas! Youroo!!
Old 03-29-2016, 10:40 AM   #15
I have a 2005 Georgetown 325 SE and want to replace the existing rectangular tail lights with an LED assembly to provide more visibility both in the daytime and night.
Is there a unit that will easily replace my incandescent lights?
dmoore1776 is offline   Reply With Quote
Old 03-29-2016, 02:19 PM   #16
B47
True - but if it's snowing outside,that means it's cold outside also. I'm guessing The overhead bulbs are inside - makes a difference.
Old 03-30-2016, 12:54 AM   #17
Dmoore1776... if your tail lights are the single rectangle with the reverse white lens in the middle, then I'm not sure. On Ebay, there are many different led lights that you might want to browse threw. Maybe Amazon also. I hope you find what you want.
Old 03-30-2016, 10:56 AM   #18
Iggy's Avatar
This is my OEM LED tail lights in my 2012.
led, light
