Old 09-09-2014, 09:44 PM   #1
Retired Ford Tech
Question LED Tail/Turn signal bulbs
I have a 2008 350se. Has anyone changed over to rear LED lights or bulbs? How did you make out?
rvpezzano is offline   Reply With Quote
Old 09-28-2014, 08:08 AM   #2
I'm using these and the work very well:
1157 and 1156 LED replacement bulb style
BobandArlene is offline   Reply With Quote
Old 09-28-2014, 08:18 AM   #3
Trailer life or Motorhome magazine did an article about replacing just the bulbs instead of the whole fixture. If I remember correctly, most of the bulb only changes resulted in less light emitted from the fixture.
Installing LED Lights on a Travel Trailer
Filthy Beast is offline   Reply With Quote
Old 09-28-2014, 08:32 AM   #4
The (Other Guy) can see these in the Daytime also! Youroo!!
Old 09-28-2014, 09:34 AM   #5
B and B's Avatar
Youroo does the LED hide the mounting holes? I noticed then at Goshen but didn't want to get arrested for stealing mod ideas
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 09-28-2014, 09:51 AM   #6
Yes if you use (2) per side they cover. I don't know why you should worry about (Stealing Mods) you Gleaned about every Mod Poor OC showed you! What about the Dumpster Diving also? Youroo!!
Old 09-28-2014, 11:12 AM   #7
Iggy's Avatar
I have a 2012 Georgetown and these are the factory LED lights that came with it.
Hopefully this will help you find a good set.
You might even look at the trucker websites as these look like the ones the truckers use.
I think these are held in by a rubber boot around the fiberglass rear cap.
Here is a link to Ebay for 4" LED stop lights that have motion rings.
See the video below the ad and see how they work.
Really cool lights.
LINK
Here is a link to the regular LED stop lights
LINK
Iggy is online now   Reply With Quote
Old 10-15-2014, 10:39 AM   #8
LED lights for RVs, cargo / utility trailers, boat and watercraft trailers and trucks has a lot in the way of tail lights / brake lights, basically all the stuff semi tractor/trailers use, and then some.
Here's a light bar similar to the above upgrade.
250-4400 15" Slim low profile RED LED tail light for trucks, horse, boat, cargo, utility trailers
led
