Left Front Clearance Light & Camera Problem
I have a perplexing problem, portions of which I have seen discussed but not exactly as I am experiencing.
When driving during the day and clearance and headlights are off everything is fine.
If clearance lights or headlights are on, the left camera always shows up on the in dash board mounted monitor and the left front clearance light near the left front camera does not illuminate.
When I switch clearance light bulbs with the right front clearance light the problem does not move. The left from clearance light does not light and the bulb moved from the left front clearance light works just fine in the right front clearance light socket. Using a DVM I measure 12 VDC in the clearance light socket. I adjusted the contacts so they hold the bulb tighter however problem still exists.
Will appreciate any ideas on root case of problem, additional tests to perform or corrective action.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
